I have a Toshiba 55H70 which had severe convergence problems. I justed replaced both STK392-110 convergence ICs which I purchased from Bluestreak International Components for $5.99 each. Put it all back together and it would not power up. Flashing power LED. I have discovered, if I unplug the green convergence connector the set will power up and the red and blue convergence adjustments will function. I could have gotten a bad IC or I got it too hot with the soldiering iron. Should I try new ICs from a different vendor or go shopping for a new set?
  • 3 more comments
  • james_higgin Mar 11, 2009
    OK, the reccommendation is to try again to replace the convergence ICs in my Toshiba 55H70. I see a lot of comments regarding replacing the STK392-110 with either STK-392-110T, STK392-120, or STK392-180. I assume the suggestion is that these are more robust parts. Which part number should I order and where should I order from to get a good part delivered quickly? The privious parts were 110s ordered from BIC.
    I don't mind investing another $40 in parts and a few hours of time if it has a resonable chance of fixing the problem. I want to make sure I using the best parts before I try since appearently a bad replacment IC was my problem the 1st attempt.
    OK, www.partstore.com is the source. Which part number should I order? The STK392-110 is what I removed. It sounds like they have a lot of heat dissapation problems. Is there an alternate part number that may yield more reliable performance?
  • james_higgin Mar 12, 2009
    Thanks. I have done soldiering but I'm not all that neet "the bigger the glob the better the job" is more appropriate for my work. Anyway, I removed the board and examined with a bright light and magnifying glass. I found nothing obvious but wicked up excess soldier and cleaned up soldiering on a number of pins. Put it all back together and still get the flashing power LED. I've pulled the board back out and plan to take it to work with me and get one of our NASA qualified soldiering techs to take a look at it. Assuming he doesn't see anything wrong with my soldiering, I was going to get him to pull the ICs and try a install a new pair of STKs. Unless you think ther is a better choice I was going to try Sanyo brand STK392-110 from www.partstore.com Do you agree? Any other suggestions?
    I have no idea what your comment regarding search for the model number refers to!
    Sergeant:
  • 300 Answers
How to replace the ic  http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
this has all the procedure to do it manually. and yes you are absolutely right it ordering parts from partselect site.they are good site for such parts. thanks. please rate the solution if helped.
Posted on Mar 12, 2009
    Filmmaker:
    Uploaded 5 video answers.
  • 98 Answers
Search for the model number. You might not need the part number.
Posted on Mar 11, 2009
  • Prabs Pan Mar 19, 2009
    You will be better off getting a new tv. Be
  • Prabs Pan Mar 20, 2009
    You would be better off with buying a new tv. because the cost for the part and the repair service will charge you about (in total) 300-600 dollors so in that money add some and you will get a new lcd screen/tv.
  • 2,334 Answers
Have you done any hand soldering before replacing the ICs?
I would suggest to double check the soldering from the newly install parts using a magnification aid of 4X. A shorted solder joint will cause the TV not to power ON unless you disconnect the geen connector from the convergence board.
I wouldn't say you got defective parts and the STK392-110 should work fine.
  • Jaime Hernandez Mar 12, 2009
    If you feel more confident to replace for new Sanyo STKs then is up to you because it could happen that the ones you've install, one might be DOA. I would also suggest to ask the tech to check the low value resistors near the convergence ICs or if you need the schematics let me know where to send you a copy.
  • 10,594 Answers
Please buy new STK from www.partstore.com
  • 11,896 Answers
Yes get the new IC's.
They all have to be new when even on has to be replaced. It isn't all that uncommon to get a bad one delivered anyways.
I would try a new one. Sounds like that is your problem.
  • Nate Stansfield
    Nate Stansfield Mar 13, 2009
    Either the STK's or sanyo's would work, STK is better for performance, but Sanyo is more reliable.
    Top Expert:
  • Televison & ... Master
  • 78,257 Answers
I had this very same TV with the very same problem, don't waste your money on the parts, it will still have a problem that will require a TV tech to fix, the cost about $600 US
The picture on my Toshiba 55H70 is distorted. Most of the screen is fine, but the bottom left looks bent with all three colors misaligned. I tried adjusting the convergence some but it did nothing for that...
hello am rico, you need to replace your convergence ics (stk392 or 393 something esle). check for caps,fuses, resistors, cold solder in the boards. if you need more help, feel free to call at anytime. 602-810-7149.
Jan 07, 2011 | Toshiba 55H70 55" Rear Projection...
What causes the yellow and blue ghost on tv, and how to solve it. It is on a Toshiba rear projection
The problems ur tv have is known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 25, 2010 | Toshiba 55H70 55" Rear Projection...
Convergence problem w/55h70. red is ok but can't fix blue. Is there a component or board that is easily replaced?
Yes,U have some basic machanicals skills?The Toshiba Tv convergence board,it call a Hyper board.Try website Ebay.com to buy a refurbish board.This board no longer produced by Toshiba,if can't find it.The Convergence 2 STK ICS,and some or all it resistors,must replaced manually.Must have tools,and knowing how to do basic soldering,to do this.
Apr 06, 2010 | Toshiba 55H70 55" Rear Projection...
I have double images
Convergence is dead.U know how to solders? Replaced the 2 convergence ICs and some or all it resistors.Buy a convergence kit at Tv repair World.com,Tvrepairkits.com to fix it ur self.The shop will cost u $300 for parts and labors.
Feb 27, 2010 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70
It could be that this time the convergence module went. I have replaced many convergence ICs and don't believe I have ever had any go out within 6 months. That does not mean that they can't. Remove the leads from the convergence area to isolate the ICs as you said you were told. Now remove the digital convergence board which should be nearby and probably will be in a metal box for noise protection. If you can I would unsolder the convergence ICs to totally take them out of the circuit and just in case one or both shorted out. Once everything I talked about has be removed try the unit. If your problem is in the convergence only your set should work but have an ugly picture. Let me know what you find and we will go from there.
hardrocko
Feb 06, 2010 | Toshiba 55HX70 55" Rear Projection...
Power light blinks off and on, nothing else
try unplugging the three convergence yokes then try powering up the set to see if it powers up. If it does replace both convergence ICs
Feb 03, 2009 | Toshiba 55H70 55" Rear Projection...
I cannot adjust the convergence.
You have convergence output failure. The output ICs will need to be replaced and possibly a small component like a resistor or two as well. Expect to pay a service company $350-$450 to resolve this.
michtech
Jan 23, 2009 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 lack of convergence, then no picture at all
Replace Both of your STKs they are your convergence ics they are big black ics have STK number on them if they are using 110s upgrde to 180s STK392-180 they are better ics. Call Electronix Parts 1-800-223-3205 they will have STKs.
Dec 24, 2008 | Toshiba Televison & Video
Blue conv. not adjustable
you will need to change both convergence ics they are STK392-110. You can get replacement ICs at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jul 25, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 55h70
sounds like the convergence ICs are defective and need to be replaced, they are STK392-110 you can get replacement ICs at the following link that include free instalation instructions.
Jun 06, 2008 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
