Question about LG DLE2532W Electric Dryer
Not drying Has little heat but not drying thouroghly
  • 462 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like an operating heater thermostat. It is usually on the area next to the heater but not on the heater. Sounds like its opening to early. But it could also be bad air flow causing a safety to open. Could also be the timer not completing the heat circuit to the correct place on the heating element. You would need a wire diagram to see if you have more than 1 operating thermostat. and a timer circuit diagram if it has more than 1 heat setting. If you read diagrams these will explain themselves.
If you feel confident here are the main things to do on checking for no heat Electric Heating Dryer:
1 Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most dryer models).
If you have 220v there the heater element is out.
2 If you don't have 220v on the terminals of the heater the problem is in the controls.
The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating thermostat(s), are all suspect and have to be eliminated 1 by 1.
Hope this helps.
With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow. A kinked Dryer vent hose, lint, and plugged up fan circulator on the motor, or if yours has little holes in the inside cabinet where the air is taken to be heated and recirculated, these can get clogged with lint also and cause a problem are the 4 main causes of low air flow..
Hope this helps and please rate me accordingly Thank you and good luck.
Posted on Mar 13, 2009
Does not heat up and timer not working?
send brand name and model number so i can help you,also if it's on time dry it should count down even without heat if you have it on more or less the timer will not move without heat.heat comes on until heater cycles off when the heat is off the timer will advance a little,when the heat comes back on the timer stops advancing,it will do this until the clothes are dry.
Sep 15, 2013 | Dryers
1995 Kenmore Dryer heating issues
Sounds like a Heating element. Most towns have a do it you self appliance repair store. Contact them to price the part. Have you tryed vacuming th ling from the inside of the unit. Sometimes they get loaded with lint and does not heat efficiently. Hope this Helps.
Jun 21, 2013 | Dryers
How to clean a 15 year old 110v air conditioner.....we removed it from the window and set it on the it okay to was out with a garden hose and let dry thoroughly before reinstalling and...
Yes it is fine to wash coils thouroghly with high pressure sprayer nozzle on garden hose. You can also blow out with compressed air and use small brush to clean fins or blades on fan.Dry completly and clean filter before you reinstall it. Thank you.
Jul 08, 2011 | Whirlpool ACC108PS Air Conditioner
When I turn on heat, hot air from driver's side, but passenger's side blows cold. Is this something I can repair myself?
Normally it is a rusty control valve,
normaly the warm water from the engine heats a radiator inside the car the interior fan then blows air theough this heater radiator making your air inside the car warm.
now in this case you have two radiators and two valves, depending on where you want the heat left or right the appropriate valve will open.
normaly you can follow the water pipes to just before they go into the car there are to grey cylinder looking things with a plug.
You can try taking the valve out, opening it up clean it thouroghly and re assemble.
Feb 15, 2011 | 1996 Buick Park Avenue
Dishes are not dry anymore after cycle?
Hello there:
If` you ahve already checked all of the filters and they are ok than your drying cycle has problems to check these check these: Heating element Drying fan Thermostat Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat. there:
Normally if you have just started to have this problem and you have checked all of the filters and are sure they are ok than
Jul 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Furnace filter gets black within 1 day. Electric furnace is 5 years old
I would take apart the burner and have it cleaned out thouroghly for its full of carbon
Jan 14, 2010 | RTO Home Heating Products 5.5HH240...
There is a lack of heat. It gets a little warm
Please ensure that the venting from the dryer to the outside of the house is clean and free of lint.
Ensure the venting behind the dryer is not kinked.
Long time to dry issues are usually caused by restricted venting to the outside.
Since you have heat this may solve the problem.
Jan 13, 2010 | LG DLE2516 Electric Dryer
Intertherm m1m furnace board says low flame yellow lite flashes 3 times Not getting enough heat
The system most likely just needs to be cleaned thouroghly. The burners, orifices, ignition assembly and flame sensors get diry, rusty, and contaminaterd. That causes low gas flow, and improper flame pattern. The othe possiblilty is a cloged or failing gas valve.
Nov 05, 2009 | Heating & Cooling
Maytag Neptune gas dryer sense dry time at 99, little or no heat
If this is a gas dryer, I'd suggest an inspection by the gas company or qualified technician. If the jets aren't firing correctly, you are wasting gas and possibly creating a hazard.
Mar 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Will not dry clothes fully. the machine heats fine but it takes two or more cycles to fully dry a little load. someone told me about a part that may need repaced around the lint trap.. Any ideas?
Your lint exhaust is blocking the heat flow.
Remove the vent from the rear of the dryer and run a timed cycle load for 40 minutes.
If laundry is dry, repair the outside vent.
If not dry,open the dryer cabinet and clean the inside lint and heat vent.
Mar 05, 2009 | Kenmore Dryers
LG DLE2532W Electric Dryer Logo
211 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
