Question about Genius Micro Traveler 900BT 3-Button Bluetooth Mini Notebook Optical S
Cannot connect genius traveler 900 to bluetooth
Why will my Samsung galaxy tab A no longer connect with bluetooth?
How to Connect Your Samsung Galaxy Tab Using Bluetooth ...
www.dummies.com/.../how-to-connect-your-samsung-galaxy-tab-using-...
Bluetooth is a wireless communication used to connect the Galaxy Tab to ... don't forget to turn them off when you're no longer using them with the Galaxy Tab.
samsung galaxy tab 2 connecting to a bluetooth keyboard ...
? 1:46
https://www.youtube.com/watch?v=-YVaAFn4vAo
Feb 10, 2013 - Uploaded by David Hodges
how to connect your samsung galaxy tab to blue tooth keyboard. ... I can connect other bluetooth items to my Tablet but notkeyboard.
Troubleshoot issues related to Bluetooth and your Samsung ...
Jan 16, 2016 | Samsung Tablets & eReaders
Connect a bluetooth speaker to a tablet
Press the sync buttom if there is one on the speaker or make sure it's charged and turned on. Turn bluetooth off and on again and it should see available devices. If not goto setting of tablet find bluetooth and scan for sevices while speaker is in sync mode.
Pair and connect.
Enjoy the tunes.
Feb 01, 2015 | Visual Land Connect Android 4.0 Internet...
How do I get cnm touchpad 9 to authenticate wifi connection to the internet, what are the correct settings, keeps connecting to bt fon instead.
I am assuming you are on an Android platform, so the first thing you should check is to see if your Wifi is on....Settings, Wifi, then usually there is a on/off switch at the top...if its off turn it on and then try to join the wifi AP. If the wifi is on and your still connecting via bluetooth then shut bluetooth off, settings, bluetooth and try connecting...maybe there is a default setting somewhere forcing you to use the bluetooth ...I'd need to know what OS your using and the version number to give you direct information.
Dec 22, 2014 | Tablets & eReaders
How do you get the rca RCT6378W2 tablet connected with a Bluetooth keyboard
If your tablet is Bluetooth-enabled, follow the set up instructions that came with the keyboard. Basically, you turn Bluetooth on on both the keyboard and the tablet. Start the process of pairing and connecting from the tablet. If you are asked to enter a password/passkey and it is not specified in the keyboard's manual enter '0000' or '1234' (without the quotes). Note that the password is required only for pairing, therefore it will happen only the first time. If your tablet is not Bluetooth-enabled, you cannot connect the keyboard to it.
Dec 21, 2014 | Tablets & eReaders
Can you hook up bluethothspeakers if you dont have bluetooth setting insettings
The device that is to be connected to the speakers must be Bluetooth enabled or it cannot be connected! If it is Bluetooth enabled then there will be Bluetooth settings!
Nov 08, 2014 | Tablets & eReaders
How do I connect NEXT7P12-G to bluetooth keyboard?
It looks like your tablet is not Bluetooth-enabled, in which case you cannot connect the Bluetooth keyboard to it. You may try to connect a regular keyboard via the USB port on the tablet (although I believe that USB port may accept only flash drives).
http://www.nextbookusa.com/pdfs/Next7P12-8G%20Tech%20Spec%20102412.pdf
Sep 07, 2014 | Nextbook Next7P 7" Tablet
Ipad A1396 is disabled it says to connect itunes but itunes does not connect or recognise it
This is a job for an Apple Genius. You will have to make an appointment online with a local Apple store.
Jan 28, 2014 | Apple iPad 16 GB 3G Tablet PC
Trying to connect bluetooth wireless keyboard
The MID9740 doesn't have a bluetooth module so you can't connect anything to it by bluetooth.
Dec 28, 2013 | Coby Kyros MID9740-8 8GB 9.7" Capacitive...
I updated my ipad to ios7 and my Targus Bluetooth keyboard does not work anymore.
I have similar problems with my Targus keyboard connection to ipad w/ ios 7, but not yet found solution. In my situation, connect can only be made after a complete power down. Keyboard is on; Bluetooth is on; iPad says it has discovered and connected to the Targus Versavu Keyboard, but keypad does not respond.
Oct 10, 2013 | Targus BLUETOOTH KEYBOARD FOR IPAD
Bluetooth won't connect
The bluetooth device drivers of your laptop may not be updates. Browse Dell's website and download and install the latest drivers for you specific model. Also try to connect witout authentication and see if it works that way.
Sep 24, 2013 | Dell Latitude Xt3 Business Tablet...
Genius Micro Traveler 900BT 3-Button Bluetooth Mini Notebook Optical S Logo
Top Genius Tablets & eReaders Experts
Are you a Genius Tablet and eReader Expert? Answer questions, earn points and help others
