09-545 The machine's toner gas gauge is disabled.
Toshiba E-studio 212 How do diserbleToner recognition sensor
Oddly enough, I just had the same problem with "OEM" toner. The chip on the toner bottle was not working correctly. I installed another toner & the bottle was detected. The bottles that did not work I throw out. You may want to try to return the bottles that are not working correctly.... Good Luck
Apr 11, 2013 | Office Equipment & Supplies
1970 Ford F100 Gas Gauge Not Working
It may be the sending unit in the tank that needs replacing. Here's how you can check: Turn the key on and disconnect the sender unit at the gas tank. Ground the sender unit's wire with a jumper wire from the truck's harness to ground. Watch the gauge. If the gauge on the dash is good, grounding the sender wire will cause the gauge needle to react and should move to full. This would indicate a new sending unit is required. If the gauge doesn't move when the sender unit is grounded, the gauge is bad and needs replacing. Pull the instrument cluster out to replace the gas gauge. Likely any old ford gas gauge might work-back then, there were not so many production changes.
Nov 14, 2012 | Ford Cars & Trucks
On my xerox workcenter 5135, the toner guage is disabled, how do i fix this?
This means that the toner is low and the machine is waiting for the empty signal OR it has been disabled as part of a software update. It has no effect on the operation of the machine.
Nov 05, 2012 | Xerox WorkCenter Office Equipment &...
Aficio MP161 Toner bottle doesn't turn to add toner.
How many copies on that machine? The photoconductor unit on that model only goes 45,000 copies. If the machine wont tone up and the pcu is old i would replace it and calibrate to see if the problem goes away. The pcu is cheap for that model. Start there would be my advice.
Jul 23, 2012 | Ricoh Aficio MP 161 Black and White Copier
1989 MB 190e: runs out of gas when fuel gauge shows not empty. Need to know the tank capacity so I'll know if it's the gauge or something else
You will need to replace the fuel level sensor, this involves the removal of the fuel tank to access the sending unit.
Jun 08, 2012 | Cars & Trucks
Gas gauge
Guess I'd have to see your gauge to understand what you mean by it turns in a circle. If the gauge is bad you will have to remove the instrument cluster to access it.
If you ground the fuel guage sender wire from the tank's sender unit you can determine whether the gauge itself or the sender unit in the tank is bad.Here's how: Unplug connector at tank. Locate the right wire (gauge sender wire) in the connector and jumper it to a good ground. Observe dash gauge when you turn key to on. If the gauge is good it will move up to half or full when grounded. Then problem is likely the sender unit in tank. But if gauge doesn't move, then it's likely the gauge itself.
Good luck.
Nov 20, 2011 | 1997 Chevrolet Tahoe
Jus bought a 91 izusu pick up... gas gauge doesnt work.. wat do i gota do to fix this??
Talking about fuel gauge issues and how do you how do you diagnose, ... is the dash unit right here, and obviously the gauge doesn't read correctly. ... to fix the fuel gauge, so you can actually fix the fuel gauge electronically by reflashing the program. ... How to Troubleshoot a Malibu Fuel Gauge & Dash Light Not Working ...Could be a bad fuse - fuse # 17 is a 15 amp fuse for the fuel gaugeCould be a bad float on the fuel gauge sending unit inside the gas tank ( it's with your electric fuel pump ) If the float gets a pinhole or crack in it , the float fills with gas and sinks so the gas guage reads empty all the time Could be a wiring problem
Oct 15, 2011 | 1991 Isuzu Pickup
I have e-studio 355, machine is indicate low toner. I replaced new toner cartridge but the machine show "toner not recognize". I try to replace the ic at the back of the old toner cartridge and...
Do not go very far yet, the problem is with the toner so I recommend you do what the machine says before looking somewhere else. replace with correct toner.
If you have a friend with the similar machine which is working properly try and get their toner put in your machine if it works buy similar toner if does not then it is the machine. You can also try your unrecognized tone in another machine see the results. The problem is just toner and the sensors in your machine.
Jul 14, 2011 | Toshiba e-Studio 205 Copier
Where is the toner sensor on the toner holder in the DCP-7020 it keeps telling me toner is empty and toner should not be empty yet.
If you look at your toner cartridge you should be able to see a clear plastic circle. That's part of the toner level mechanism. I've gotten a few more prints out of my cartridges by putting a piece of tape over the clear plastic and coloring it black with a sharpie. However, there are other mechanisms used to gauge toner levels, and this will not be a permanent fix.
I've also gotten a little more life out of it by simply shaking the toner cartridge for about 15 minutes. It helps coat the inside and might break up chunks inside the cartridge itself.
Jun 16, 2011 | Brother DCP-7020 All-In-One Laser Printer
Toner sensor error
Hi
This error comes up when the printer detects that the toner of particular color is missing. This indicated that the indicated color toner is missing from the printer(eg-- C = Cyan, Y = Yellow, M = Magenta, K = Black).
C5150 may face a toner sensor error after installing used sets of toner cartridges and sometimes even after installing new toner cartridges as well. This error can be bypassed. This can be disabled by following these steps---
1. Turn machine on while pushing and holding the (+/-), menu buttons at same time.
2. Menu window will show OKI USER.
3. Scroll to Engine Dialog Mode is indicated Push Enter button.
4. Diagnostic Mode xx xx xx S Mode is indicated.
5. ( = 2 ) . Press (- or +) button until “ENGINE - PARAMETER SET =2” is displayed.
6. Push Enter button.
7. TONER SENSOR - ENABLE is displayed.
8. Push Enter button.
9. Press (- / +) TONER SENSOR = DISABLE is displayed.
10. Press ON LINE CANCEL buttons at same time.
11. (*) is displayed.
12. Restart the Printer.
Daniel Scott
Jun 22, 2010 | OKI C5150n Led Printer
225 people viewed this question
k24674
