Question about Honeywell Programmable Thermostat Heater
Honeywell thermostat for a/c heat pump shows the following message LO 6AEE then screen goes blank and a/c won't come on
  • Honeywell Expert
  • 252 Answers
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
Hunter 44860 touchscreen thermostat- My thermostat displays "LO". My wife said she played with it and can't fix it. He heat won't shut off! I thought it was the batteries so I replaced them. I noticed...
I suggest to everyone NEVER to buy a cheap thermostat from any box store regardless of brand. Always go with Honeywell or White Rodgers high end stats and DO NOT lose their booklets.
Feb 19, 2015 | Heating & Cooling
Heating won't go off
Honeywell manuals are online for all its thermostats.
Google search your model number.
Model number is on back of thermostat.
Copy following link for Honeywell resources:
http://yourhome.honeywell.com/home/Applications/FindYourModelNumber.aspx
Honeywell manuals are detailed, but each pdf file can be word-searched.
More resources:
http://www.ehow.com/how_6596826_troubleshoot-honeywell-thermostats.html
Jun 25, 2012 | Hardware & Accessories
Blinking message LO 6AEE what does it mean?
It means you need to cange the batterys.
Jan 20, 2011 | Honeywell TH4210D1005 Heater
I have a Honeywell CT500A thermostat. I set it at 68 degrees. the room temperature is 62 degrees. The unit cycles on and the "flame" icon shows on the screen, but then the unit goes off ( the...
Here is a simple way to tell. Remove your thermostat from it's mounting plate, locate the wiring, the red and white are low voltage control wires. Disconnect them from the base and join the two together if the furnace runs you need a thermostat if not it is in the controls to the furnace.
Dec 27, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
Bae lo This is the message my electric Honeywell programable thermostat is flashing. It's still working. What's that mean? Thanks.
Try with this site:
Honeywell thermostat website: http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating
Dec 12, 2010 | Heating & Cooling
I changed the batteries of the Honeywell thermostat and on the screen it still shows low battery.
Hello my name is Heath it will be my pleasure to assist you. Take the new batteries out and let the display go completely blank then reinstall the new batteries and the lo batt light should go off.
Nov 08, 2010 | Honeywell Heating & Cooling
I have an old (14 years) honeywell thermostat, that showed 1bat lo message on the screen. I replaced the batteries, but it still shows the same message and I cannot adjust the temp. I recall earlier...
I subjest the honeywell pro 3000 is a very good stat it comes in programable and non programable their is also a pro 8000 that is great its touch screen and has many options but the 3000 is most cost effective
Sep 14, 2010 | Honeywell Programmable Thermostat Heater
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
My thermostat
Maple chase is the same I believe.Sounds like the thermostat is bad.I personally think the Honeywell 3000-4000 series thermostat are better.But the Maple should work!
Aug 18, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
285 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
