I have a Boston Acoustics MCS 95 subwoofer. An electical componant circuit board is partially fried. It's a plug & play part that I have removed and is my hand. The only identifier I can find
See above.
4 Suggested Answers
SOURCE: My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
Posted on Feb 20, 2010
tbreeze47
  • 3083 Answers
SOURCE: My ALTEC LAnsing subwoofer speaker
Well, I'm thinking like you in that only part of the circuit board in the subwoofer box is bad, since it's feeding a signal to the desktop speakers. You might take a shot at it, it's a lot cheaper than buying the whole board, I would think, but check before you change it out- sometimes the ICs are custom made and hard to get, if not impossible- hence, they make you buy the whole board (this happens a lot these days with all appliances).
The only way you can know for sure is to troublshoot it with a scope (minimum) and shematic, and possibly some other high tech equipment, if you have access to it (audio generators, etc.).
Before you change the IC out, inspect the circuit board carefully (with a loupe or magnifying glass) for bad or cracked solder joints- they can occur with time and/or heat and open up, and merely need to be resoldered.
Good luck, and hope this helps.
Posted on Nov 07, 2010
bronk50
  • 27725 Answers
SOURCE: Boston Acoustics BA745 2.1 Analog Speaker System.
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer hope this helps
Posted on Apr 11, 2011
Height above sea level of my house in Southampton
3 metres
Geographic coordinates of Southampton, United Kingdom. Latitude ...
dateandtime.info/citycoordinates.php?id=2637487
Latitude of Southampton, longitude of Southampton, elevation above sea level of Southampton. ... Coordinates of Southampton in degrees and decimal minutes. Missing: my ‎house
Southampton - Wikipedia
https://en.wikipedia.org/wiki/Southampton Southampton is the largest city in the ceremonial county of Hampshire, England. It is 75 miles .... The city walls include God's House Tower, built in 1417, the first ..... [hide]Climate data for Southampton, elevation 3 metres (9.8 feet), 1981-2010 ... The centre of Southampton is located above a large hot water aquifer that ...
Frequently asked questions about Southampton in Queensland - Bonzle
www.bonzle.com > home > homesteads > Southampton
myBonzle menu: Add to my places Add picture Add story Add note. Skip to map ... What is the elevation/altitude/height above sea level of Southampton? Southampton is at an ... Old Parliament House, East Parliament House Picture relating to ...
An Oceanfront Home Built Above Sea Level ' Southampton, House ...
https://www.pinterest.com/pin/172122016986387096/
Southampton · House · House beautiful ... Balconies · An Oceanfront, Southampton Home Built 17 Feet Above Sea Level ...
Height above sea level of my house in Southampton Google Search
Oct 16, 2017 | Computers & Internet
Tip
Perform Nozzle Check Pattern of Canon Inkjet Printer without Computer
Models:
BJC3000 and above,S300 and above, i450 and above,Pixma ip2000 and above
Procedure:
  • Set A4 paper in paper tray.
  • In stand by condition,hold down Resume/Cancel button until LED indicator blinks twice then release the button.
Models:
Pixma ip1200,1300 ,1600,1700,1800,1900,2200
Procedure:
  • Power on the printer, immediately after printer standing by press Resume/Cancel button 5 times within 2 seconds.
The printer start printing nozzle check pattern after procedures above performed properly.
on Dec 02, 2008 | Canon S400 InkJet Printer
How do you repair blown Boston Acoustics Subwoofer MCS Amp?
Most often this unit goes dead because of zener diode ZD3 shorting. It is a 18v zener. replace this and you should be back in business.
Feb 20, 2017 | Boston Acoustics Audio Players & Recorders
Question mark key and slash plus 2 keys above it have turned to eee with accent above
https://support.microsoft.com/en-ca/kb/258824 - I suggest you check out this article - or you can google yourself - How do I change my Keyboard Mapping? and then see what comes up.
I would appear that you have somehow setup something on those keys - e with an accent above is most likely French
May 28, 2016 | Logitech Computers & Internet
Subwoofer blows fuse
Short circuited component/s at its circuit board. Check and replace it. Check for shorted component/s at the amplifier stage circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 06, 2015 | Boston Acoustics Audio Players & Recorders
Why is water leaking into cool (deli) drawer?
Hi,have you got a drain at the back of the fridge just above the veg draw,if yes is there eney food above that that is tuching the back wall of the fridge above the veg tray,if so then the water that runs down the back wall will be going onto the food that it tuches and into the veg draw,hope this was some help,all the best.
Sep 16, 2015 | Refrigerators
MCS 160 Boston Subwoofer ZD3 Zener Diode Value
ZD3 is a 18v zener. Also check the surface mount resistor on the back of the board that is attached to ZD3, I think it is R9. Should be 10 ohms. This resistor sometimes opens when the diode goes short.
Jul 13, 2013 | Audio Players & Recorders
Boston Acoustics subwoofer keeps cutting out
Some subwoofers have a turn-on delay circuit at the input to prevent "popping". Unless the input remains at a certain level, the delay circuit turns off the sub. The only solution I have found is to change to another sub that is not so protective
Apr 01, 2013 | Boston Acoustics ASW650
Avr 1513 no signal to subwoofer
Check its speaker connections. Check the speaker using a dry cell. If it is found OK, check the sound settings. If you wish to get more details, check this link.
Mar 22, 2013 | Denon AVR-1513
I also have a fried zd3 on my boston acoustic mcs 95 Sub amp board. Do you know the radio Shack part number you used and did your amp power up? My Sub is not working. No power and no green light but my...
zd3 is a zenna diode, you will need to find the volts that it triggers at, most amps (99%) have a mirror circuit board so all components are dobbled so this will help you find what you need Re: Jeff
Nov 25, 2012 | Radio Communications
Open Questions:
183 people viewed this question
 Grubhead
Grubhead
