Question about Grilling
Master forge grill flame too low
Grill ignites but will not produce high flame
  • 36 Answers
SOURCE: Kenmore Master Flame Grill
Burner will not light:
Here is a couple things you can check:
1. Gas injector not insert in venturi tube.
2. Clogged gas injector
3. Obstruction in gas line.
4.Spider webs in venturi tubes.
5. Misalignment Of collector box and burner.
6.Dead Battery.
7.Check hose to make sure it is not kinked
8.Check Hose to make sure it wasn't chewed by squirrles
9. If it is LP gas, Could be out of gas.
Other Issues:
Could be the way the grill was turned on and off, that also can be an issues. In your manual it will tell you how to do it proper, this could make it not light or have a low flame. If there is not hing in your manual, I will be happy to assist you.
Fireplace-Girl
Posted on Apr 29, 2008
SOURCE: gas grill prob.
Barbecue Repair Parts Don't let spiders crawl into your venturis, yearly maintenance part are available. 27897.jpg?qlt=80&cell=325,325&cvt=jpeg If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS. 27898.jpg?qlt=80&cell=325,325&cvt=jpeg In some areas of the country, spiders or small inserts have been known to create "flashback" problems. The spiders spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury. To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI assembly should be removed from the grill and cleaned before use whenever the BARBECUE has been idle for an extended period of time.
Also, when you lite the BBQ, make sure that you turn the gas on at the tank, wait a couple of minutes and then turn the knob on and light the burner. This is to make sure that the pressure is regulated and sufficient prior to lighting.
Hope this helps!
Posted on Sep 25, 2008
  • 512 Answers
SOURCE: flames only come out very low on both sides
disconnect tank, hook tank back up, then open valve slowly. When opened to fast it thinks valve is leaking and shuts down.
Posted on Jun 13, 2009
SOURCE: cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
Posted on Oct 13, 2009
gcken
  • 140 Answers
SOURCE: It only gives low flame upon starting and cannot
close your air vent on the burners it will increase the height of the flame
Posted on Apr 04, 2010
Need a manual for Master Forge Smoker Model 32930
I'll save you the trouble. The master forge web site sends you to sears parts. Sears parts does not recognize this model number. This is another example of how Lowes sells mass produces products with little or no customer support. This item was for sale online but is no longer. Online sales is how many box stores remove items from stock that are either out of production or no longer being purchased by them.
Aug 15, 2015 | Grilling
Gas grill ignighter
Does each knob have its own igniter and do all of them not work
Jun 21, 2013 | Grilling
Master forge grill won't light with 2nd propane
Here's the problem and how to solve it. When you opened the valve on the tank, you did it as you normally would. However, the new OPD Valve tanks will often shoot a heavy load of gas to the regulator and lock it up.
To hopefully solve the problem, do the following:
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow), until the valve is fully open.
Then light the burner farthest for the tank first. Did the burner light and does the flame height
look correct? If so, light the remaining burner(s) the same way. Do all the flame heights look
correct? If so, you solve the problem. Remember to always open the tank valve Very, Very
Slowly.
If that didn't solve the problem, you will need to replace the Grill's Hose/Regulator Assembly. You can pick one up at any hardware store or home center that sell grills and accessories for about $30.00. Take you old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy grilling!!
Jun 28, 2011 | Grilling
I have a Weber gas grill, and I just replaced the propane tank, yet when I ignite it on the Start/High setting, very little flame is produced. This is the first time in 5 years or so that I've...
Don't worry, you'll be grilling in no time, if you follow these instructions:
1. Turn the gas tank valve OFF.
2. Disconnect the grill's hose from the propane tank and wait 5 minutes.
3. Reconnect the hose to the tank and open the tank's gas valve VERY, VERY SLOWLY (Slow Motion, slow).
Once the valve is fully open light one burner and turn it to HIGH. Has the flame height returned to normal? If so, light the remaining burner and turn it to HIGH. Do both flame heights look normal?
If so, you solve the problem! Remember to always turn the tank valve ON Very, Very Slowly.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 16, 2011 | Weber Baby Q Grill
Will not produce high flame properly
You probably have a bad regulator which you can buy at most stores that sell BBQ's.
Apr 07, 2010 | Char-Broil Performance 463463006
Genesis s310 stainless grill. Does not fully light.
Regulator is not bad, as I stated before new valves are designed to reduce gas flow if valve is opened to fast. This is so if grill catches on fire, the tank will shut itself off, thus propane will stop flowing causing fire to extinguish itself.
Dec 28, 2009 | Weber Genesis E-310 Gas Grill
I have a gas grill that has set for about two years and now it has a low flame when gas is set to high. Is it the burner or the regulator
I shut off the gas at the tank and grill. Removed the regulator from the tank and turned on the knobs on the grill for one minute. Then turned off the grill reconnected the gas line to the tank and opened the tank knob slowly.
Oct 31, 2009 | Char-Broil CharBroil Master Flame Gas...
Flames only come out very low on both sides
Jun 11, 2009 | Char-Broil CharBroil Master Flame Gas...
Charbroil master flame gas grill the flame is either very high or very low
How old is the grill? The size of the holes in the burner is critical. As burners age, the holes rot out, and get bigger. The velocity of the gas exiting the holes has a large effect on flame size. New burner is the most typical solution.
Mar 08, 2009 | Char-Broil CharBroil Master Flame Gas...
Grilling Logo
76 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
