Question about Tanita BF 350 Pro Body Composition Analyzer
Connect tanita bf 350 to pc - Tanita BF 350 Pro Body Composition Analyzer
2 Suggested Answers
SOURCE: does having water effect the
Yes. These systems work by what could be broken down as, "Bio-electrical Impedance Monitoring".
Meaning, they measure the amount of resistance in your body to determine the "volume %" of non-resistive materials (fat and water). Since bones and muscle are very dense in comparison, the scale can calculate the total weight of a person, then determine their "expected BF%). Fat is about 80-90% water depending on your genetic makeup, and it would only make sense that if you where full of fluids (either by ingesting large amounts or by fluid build up under the skin) that your BF% would read higher. My professional suggestion? Use it only after waking and before any morning drink or food.
(REMEMBER...THESE THINGS WILL NEVER BE EXACT!!!) Hydrostatic weighing in the only way to be 99%+ on your BFC (body fat composition)
GOOD LUCK AND PLEASE RATE THIS POST!!
P.S. one way to test this method is to hold something heavy in your hands and watch it consider that weight Lean Muscle Tissue. Then stick your hands in a sink full of still water (moving water posses a small electrical charge that could give a false reading) and watch your BF% increase.
Posted on May 09, 2011
Error code r5 on Tanita BF-350
Just spoke with Tanita Tech support- r5 indicates if the scale is in PC mode (able to receive data from scale). There is a button sequence to toggle between PC mode and stand-alone mode.
1. Press&Hold Zero button, then Press&Hold On/Off.
2. Release.
3. Arrow buttons toggle between PC mode and Stand-Alone, select which mode you would like.
4. Press Set button to select mode.
Hope this helps!
Mar 23, 2012 | Tanita BF 350 Pro Body Composition...
Does having water effect the BF calcutations on a Tanita 1250053 BF-350?
May 09, 2011 | Tanita BF 350 Pro Body Composition...
Someone has switched my tanita BF 625 to metric readout and i don't know how to switch it back
Press the set and arrow UP button at the same time. Then use arrow UP to find lbs. Press the set button to confirm.
Jan 29, 2011 | Tanita Digital Body Fat Scale with 2...
I had to change the batteries and now it only reads in "kg" how do i change that on the model 2204?
Since your problem started with a battery change, I am going to assume that method 1 is most likely going to fix your problem...Good luck!
Method 1
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Jan 12, 2011 | Tanita 2204 Body Fat Scale
Need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
Tanita innerscan stopped working. New batteries installed but will not switch on. There is no display except on the guest button which comes up with "88888" when pressed. Any ideas - thanks
Maria,
sorry no, i don't have a sltn. however i recently experienced the same issue w/ my tanita innerscan. i've just notified Tanita's customer service... have you had any progress?
Dec 30, 2009 | Tanita BC-533 InnerScan Body Comp Scale
Error reading 5
be sure you are barefooted when weighing yourself
Oct 05, 2009 | Tanita BF-350A - Body Composition...
Getting error E 11 on unit.
ok here is what I found: •E - 11 is displayed when there is a loose connection between the control box and the weighing platform.•Confirm that none of connections between the scale and control box are loose or unplugged.•There may be excessive vibration which will disturb the measurement process.
you can dowload the manual here http://www.tanita.com/en/tbf-300a/184-catId.520093719.html. If those solutions do not work i reccomend contacting the manufacturer here http://www.tanita.com/en/contact-us/ as the unit may be under a warranty.
Apr 01, 2009 | Tanita TBF 310 High Capacity Pro Body...
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Method 2
Mar 15, 2009 | Health & Beauty
Scales show weight in kg. How to get them to show lbs.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Tanita BF 350 Pro Body Composition Analyzer Logo
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
