Question about Magellan Maestro 4040 GPS Receiver
Fixable at home?
I went in and plugged the unit in and the battery was not taking a charge...critically low....then it shut down....I feel that the port is loose or broken off and now unable to plug in what so ever to charge the battery...the corp says they can't help me, just replace the unit...$$$
Anything I can do at home...?
  • spraguehvl Mar 14, 2009
    magellan 4040 will not power up using car or plug in source
  • lgeis May 10, 2009
    Magellan 4040, approximately 16 months old, regular use. Plugging into the DC source gives about 2-3 minutes of operation, then a warning screen pops up saying that the battery is critically low...then the unit shuts off.
    President:
  • 1,111 Answers
I can sell you a new port or repair it for you
Posted on Jun 03, 2009
    New Friend:
  • 15 Answers
This problem is a design flaw on all Magellan Maestro GPS from the 3100 series to the 4xxx series.  This problem can easily be fixed, but you need to be handy with a soldering iron.
NEEDED: 1. Fine tip soldering iron, solder, soldring flux or paste.
1. Remove the four screws on the back of the unit holding the back cover to the GPS 2. Pry open but be very careful, make sure the SD card slot is empty 3. Open from the SD card slot side and then remove the cover slowly, remove the speaker cable 4. Use soldering paste or soldering flux, apply some to the leads of the yellow female DC port on the PC board 5. Heat the soldering iron to temp, and then press the solding iron against the leads of the yellow dc port and also apply some solder. 6. Do this to all four terminals of the dc port 7. Now plug in the dc power jack into the port and make sure the unit is charging...  8. Replace cover, make sure the audio and power jack is in the slot first, then close the cover and screw in the 4 screws.
DONE!
Hope this helps
Posted on May 27, 2009
Critically low battery displayed on pioneer sat nav
There's a replaceable Li-on batter inside. Mine is a model 338937010176 3.7V 790mAh which I'm struggling to find online
Nov 15, 2012 | Pioneer Avic-f310bt,avicf310bt,avicf310...
Verizon MiFi 2200 blinks red then shuts itself off when I plug it in. I know red blinking means critically low, but it won't charge and I have left it plugged in for hours. I held the reset button down for...
Mine did this, I went to Best Buy where I bought it. They didn't really seem to know, said it could be the power cord to the wall, but they didn't sell them. But they could set me up with an upgrade (and new 2 year contract that I didn't want). Anyway, I went to Radio Shack and showed them my MiFi 2200 and they had the new wall charger power cord there. Works now, problem solved for $25 instead of a new 2 year contract.
Jan 17, 2011 | Novatel MiFi 2200 Mobile WiFi Hotspot...
Just done an bios upgrade everything went fine but guess what yes it went wrong the computer shut down yellow light in the upper right hand corner stayed on charging light was also on nothing on screen...
take off : power cable , battery wait 5 min
open the case take off the c-mos battery , wait 5 min
mout everything , start the machine again , whit all connections , so you did a reset from your bios
Apr 18, 2017 | Acer Aspire One AOA110-1113 Netbook
Won't start - battery critically low
You should have a light on the notebook indicating that the power supply is plugged in (this should come on with or without the laptop being turned on). My acer has a green light for power, and the battery indicator shows amber for charging and green for full. If you are not seeing the power or charging indicators, you either have a damaged power jack, or a damaged power supply. Power supplies can be purchased usually for fairly cheap online, but if your power jack is damaged, the laptop will have to be serviced by a service center, or by someone who is skilled with a soldering iron and the disassembly and reassembly of laptops.
Feb 28, 2010 | Acer TravelMate 2413LCi Notebook
Problems
Hi, i think the battery has completely run down, i suggest you get another battery and ensure you don't allow the new battery to completely run down before yo charge.
As`soon as it shows low battery, you try charge or shut down to save and give your battery long life span.
I wish best of luck
Jan 06, 2010 | ASUS Eee PC 900 Notebook
Unit comes on but goes off in a few seconds. Sometimes shows the "critically low battery" screen but not all of the time.
most likely the power port is damaged and needs replaced. i repair those magellan gps if you need help. if i cant fix it there is no charge. wmetz@comcast.net
May 27, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
No power
Hi there
Take the battery out and try to power the machine up on AC only,
Post back with the results please
Feb 01, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Acer Aspire 3610 plugged in closes down
I would suggest you just plug it in and do not power on the laptop for a few hours. Then try. If it persists reboot into safe mode and disable hibernation then reboot
Dec 06, 2008 | Acer Aspire 3610 Notebook
W850i red light prob
not to worry this is a fixable problem..............take te phone to a mobile shop and have them reflash the firmware n custom pack back into the phone and this will correct the problem....the erom needs to be loaded back on the phone.
Nov 19, 2008 | Sony Ericsson K850i Mobile Phone
Magellan Maestro 4040 GPS Receiver Logo
259 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
