Question about SanDisk Sansa e260 MP3 Player
Rockbox Firmware not installing after recovery mode on player
The player had to go into recovery mode, i put it into recovery mode. I then put in the rockbox firmware, and took the player out. The Player would again freeze on boot screen and not start properly, causing me to repeat this process.
The firmware instal intructions quite clearly tell you NOT to attempt to instal Rockbox in recovery mode. You must have it in MSC mode.
Posted on Aug 06, 2007
My Sansa Clip died after installing Rockbox!
Maybe installing Rockbox makes your device corruption. If plug the device to pc, the pc still recognize it, update new firmware from sandisk official site, http://forums.sandisk.com/sansa/
Good luck
Apr 19, 2010 | SanDisk Sansa Clip MP3 Player
Black screen that just says "load main image failed Switch to recovery mode"
okay have u tried going in recovery mode, (push power and hold at same time) may it will boot the whole system, if not look out for ROCKBOX (rockbox.org) foe new operating system
Dec 10, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e260 doesn't recognize my 8GB sandisk expansion card
Sandisk sansa e200 series players only allow up to 2GB expansion, BUT with rockbox firmware up to 32GB is available. Only download rockbox firmware if your familiar with transfering and installing files.
Rockbox firmware can be found at http://www.rockbox.org/
Jul 15, 2009 | SanDisk Sansa e260 MP3 Player
Sandisk Sansa C250 won't recognize 8Gig micro chip
Your model doesn't natively support SD cards over 4GB, however I hear you can install something called "Rockbox," it's a free third party firmware that allows you to dual boot between "Rockbox" and the Sansa firmware. "Rockbox" adds the support you need for SD cards with a capacity of 4GB or more. I've never used this firmware, but it does sound promising.
Download it here
Sorry I couldn't be more help.
Jun 03, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Rockbox problem
go to www.rockbox.org no cd required , you can download the latest version of rockbox once downloaded you can change the language on the irriver by menu/setting/general settings/lang okay
enjoy
Feb 24, 2009 | iRiver H320 MP3 Player
Max. micro sd card size compatible for Sansa C240
It depends on the version. v1 players can support up to 2GB. v2 players can support up to 8GB.
You can find out what version you have by going into Settings -> System and look at the version. If it starts with a 01 then it's a v1, if it starts with an 03 then it's a v2.
You can use a card up to 8GB if it's a v1 player by installing Rockbox on it. It's a 3rd party firmware for some mp3 players - although you should make sure to read any instructions for installing it, as well as read the manual.
-> Rockbox.org
I will stress this again: make sure you know what you are doing by reading installation instructions and the manual.
In order to install Rockbox on your player it needs to be in MSC mode (Settings -> USB -> MSC). If your player doesn't have the USB option in the Settings menu then you will need to downgrade your firmware. There's info on this in the Sandisk forums about how to do this.
Jan 29, 2009 | SanDisk Sansa c240 MP3 Player
Sansa e260 firmware
Mine was a bit more FUBAR I guess. I have a Sansa e260. I had rockbox on it, went to switch back to the firmware. Uninstalled rockbox and on reboot... the e260 was refreshing the database and then came to a frozen green screen.
My e260 was already in MSC mode. I did the steps above but was still stuck.
The solution that worked was one posted by "Slaughter" on anythingbutipod.
The ultimate fix for all e2xx v1 problems - Format, enter recovery mode, downgrade firmware Link (you'll need to format the drive), reinstall newest firmware via newest Sansa Updater, reload tunes.
Dec 01, 2008 | SanDisk Sansa e260 MP3 Player
Problems with Sansa e250 + Rockbox
Go to Sandisk's website and download the Sansa Recovery Tool
Jul 04, 2008 | SanDisk Sansa e260 MP3 Player
Windows Recovery Mode:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 14, 2008 | SanDisk Sansa e250 MP3 Player
Need help!!:completely dead
It sounds like your firmware is corrupted..go to the sandisk website to get a firmware update...
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Jan 05, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
145 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
