Question about Samsung Refrigerators
Loud fan sound when fridge door is closed
The fan seems to be working overtime when the fridge and door is closed. when opened the noise gradualy stops. it sounds like an aeroplanes propeller slowing down.
    Problem Solver:
  • 4 Answers
I just vacumed my fan and everything else that I could get to. The refrigerator runs much quieter.
Posted on Mar 11, 2009
Some fan making a loud noise. When open either
It sounds like it is probably your evaporator fan, seeing as that fan will cycle off when the door is open, and resume when you close the door. Either some how something got in to it, or it is going bad. Hope this helps
Oct 07, 2009 | Refrigerators
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Loud whirring noise that stops when freezer door is open.
It is most likely your circulation fan in the freezer. Normally the fan stops when you open the door. It is a normal operation. Check to make sure that the fan is not blocked by frozen items or that the fan doesn't have an ice build up. On some models the fans stops when you open the door and starts a few minutes later after you close the door.
Mar 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
New refridgerator delivered this morning to replace the same model that was a lemon. The fridge is making a sound on the fridge side. When I open the door to the freezer side the sound stops. When I...
sounds as if there is an issue with the evaporater fan motor, perhaps the fan blade has come dislodged and is makinf noises, normal for the fan to stop when the frig door opened as welll,
Dec 17, 2008 | Refrigerators
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Refrigerators Logo
222 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
