Question about Mirro Kitchen Appliances - Others
Mirro m-0536 11 lift pin leaks - Mirro Kitchen Appliances - Others
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
I can't find a user manual for my Sanyo Mirro cell phone.
Sanyo SCP-3810 or the Sanyo Mirro cell can be found here. http://www.kyocera-wireless.com/sanyo/usa/scp-3810-phone/pdf/Sprint_SCP-3810_User_Guide_en.pdf
Mar 02, 2011 | Sanyo Cell Phones
Mirro Pressure Canner M-0512-11 Owner manual
Howdy, Mirro is still rebuilding their website and don't have online manuals ready yet. For now, here is a brief FAQ section from their pages:
http://mirro.com/
There is also contact data so you can order a hard copy of the manual from them.
Best regards, farmerbear at FixYa.com
Sep 12, 2010 | Microwave Ovens
Coolant leaking by the firewall in the engin compartment
Check in the very back of the cylinder head's by the fire wall, there's a coolant pipe that run's from one head to the other, it's hard to get to but with a mirro you can check it.
Jul 01, 2010 | 2002 Mitsubishi Montero
I need an online user's manual for Mirro Pressure canner Model M-0526. I am not sure the unit I have has all the need ed parts. I do not see a safety pressure value - on the vent and the round thing tht...
You should never go above the 10 lbs pressure during canning. The manual recommends that you prepare the pressure cooker with 1 qt of water and 1 Tbsp of vinegar then set the unit to 5 lbs. Let the unit cool and then repeat at 10 lbs to learn how to maintain the pressure of the pressure cooker. See page 25 (page 24 of the PDF). I found the manual for the Mirro M-0526 here: https://www.appliancefactoryparts.com/pressurecookers/mirro/m-0526.html . The direct link to the manual is https://www.appliancefactoryparts.com/content/pdfs/136681-1.pdf . I also found some Mirro pressure cooker manuals here: http://www.pressurecooker-outlet.com/Pressure-Cooker-Canner-Manuals.htm .
I hope this helps.
Sep 14, 2017 | Mirro Coffee Makers & Espresso Machines
I have a mirro matic pressure canner model 0406 with a jiggler pressure gauge. how do you know when pressure is reached and how to maintain that pressure for correct time?
I too have a Mirro 0406 that my mother gave me some 25 years ago. I LOVE it and use it every year! Fortunately, she gave me the manual along with the canner. It states"When correct pressure is reached, control will jiggle and sputter. To reach the first jiggle in a small cooker may take less than 5 min, or less than 10 min, when canning. Large canner may take 45 to 60 minutes for the first jiggle when canning a full load. Count time from first jiggle and reduce heat so control jiggle about 1 to 4 times a minute for cooking (about 4 jiggles per minute when canning). Constant jiggling causes excessive loss of moisture: the occasional jiggle and a hissing sound indicates pressure is being maintained. (I just canned 14 quarts of green beans with my Mirro today 7/26/09 :) Congradulations on your Mirro canner, I hope you have many years of success with it. Good Luck, and Happy Canning!
Jul 24, 2009 | Crock Pots & Slow Cookers
LCD 3/4 Blackout canon 300D
This is fairly common on the 300D - the submirror ( underneath the main mirro ) has a plastic pin that breaks - the camera has to be disassembled to replace. Expect to pay an independent repair shop about $105 or from Canon $180.
Dec 18, 2008 | Nikon D40x Digital Camera
1969 pontiac firebird oil pan.
you can take the oil pan off by just undoing the bolts just lift the car up then since it is just pin holes you can probly just spot weld them or maybe use a high streangth solder
Jun 24, 2008 | Pontiac Firebird Cars & Trucks
Mirro pressure cooker instruction manual
You can find one here.
http://www.pressurecooker-outlet.com/mirromanual.pdf
Feb 27, 2008 | Coffee Makers & Espresso Machines
Kitchen Appliances - Others Logo
23 people viewed this question
Top Mirro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Mirro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
