Question about Teac Legacy DR-L700 DVD Player
Flashing Power Light
I have moved my surround sound system and now when I plug the power cable, the standby/power light is just flashing and nothing else happens. Hope you can help.
  • 63 Answers
Your surround sound system seem like having dry solder joint at PCB . one thing you can do is to open up the back cover first looks for dry solder joint ( if you can find ).if not just re-solder those solder looks very thin.it may help.
Posted on Aug 12, 2007
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Standby light flashing but no pic no sound on
Power Supplpy board is dead.Replaced the power supply board will solved the power flashing.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 22, 2010 | Televison & Video
Sharp AQUOS LC-26P50E television. Stuck on 'Standby'/'Sleep'
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
Sep 05, 2009 | Televison & Video
No picture
(i) Disconnect all the cables from the TV including the power cable then reconnect them after a few minutes.
(ii) Make sure that the power cord from the TV is directly connected to a functional wall outlet.
If the standby light keeps flashing then service will be required.
Aug 24, 2009 | Sony KP-53V75 53" Rear Projection...
Motorola SB5100 Cable Modem Power Lght Flashes
Call your Internet Service Provider.
They can remotely "connect" to the cable-modem, and diagnose it.
Jul 16, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
SONY NAS-EH35HD Giga juke hi fi Standby light flashing
i have similar. All gone off and red light flashing. Did you get yours sorted?
Mar 27, 2009 | Sony Audio Players & Recorders
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Toshiba TV, no power, red light flashing
Unplug the TV for 2 minutes and plug it back on.
It should work.
Feb 09, 2008 | Televison & Video
Teac DVD L700 Power Supply
The only thing I can tell you is to check the cable if its plugged in correctly... wierd! might be electricity problem to where you moved it. Did you hit it while you were moving it?
Aug 02, 2007 | Teac Legacy DR-L700 DVD Player
Teac Legacy DR-L700 DVD Player Logo
247 people viewed this question
Top Teac Televison & Video Experts
Steve Allison
Steve Allison
JOHN TOPLISS
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
