Question about Ricoh Aficio Office Equipment & Supplies
Ricoh print job stuck processing
Attempting to clear a job that is stuck in the processing status. attempt to delete reservation but that doen't clear the job.
professor_sc
  • 180 Answers
SOURCE: Print job stuck and can not be deleted
click on this link http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=mp-56143-2&jumpid=reg_R1002_USEN
Posted on Oct 22, 2008
  • 684 Answers
SOURCE: Printer continues to say ''Collecting printer status''
Uninstall the Printer Drivers and reinstall it this should work.......And for this problem this is the only resolution...........
Good Luck....
Posted on Jan 22, 2009
dburns60
  • 410 Answers
SOURCE: deleted print job stuck in queue
You can always restart the computer, that will "unstick" a print job that gets stuck deleting.
Posted on Jul 05, 2009
  • 68 Answers
SOURCE: Our Ricoh MP 171 devices go offline after one
have you tried doing a local connect using a crossover cable to the printer to see if it is the printer or the 2k3 server?
I have seen this issue when terminal services are enabled on the server.
if when you connect locally to the device using x-over it still does it it may need to have the nib firmware updated, however if it doesnt I would run a packet sniffer on the network jack that the device is plugged into and check to make sure that the port is good and transmitting and receiving all packets check the network cable and replace that and if all else fails try the device on a different network port.
Posted on Sep 16, 2009
SOURCE: My Xerox Wokcentre 4260 is
Solution : Perform an On Demand Image Overwrite (ODIO) Image Overwrite Security protects against unauthorized retrieval of confidential data from the machine by removing image data that is left when jobs are processed. When started, all of the physical areas of the hard disks holding job data are overwritten with a series of alphanumeric patterns.
There are two options for On Demand Image Overwrite: Standard and Full Overwrite. Standard ODIO will overwrite all jobs stored in image data as well as fax card image data. Standard ODIO will not overwrite fax mailbox, Poll store (mailbox 0) and dial directory information, or folders created with the Store Job feature, if these features are installed on the machine. Standard overwrite takes about 30 minutes. Full overwrite takes approximately 160 minutes to complete.
NOTE: Full ODIO will overwrite and delete all fax image data, including mailboxes, Poll store and dial directories on the fax card. Full ODIO will also overwrite any images that have been stored in folders created with the Store Job feature. When On Demand Image Overwrite is initiated, the machine is taken offline until the overwrite is completed. Any existing jobs in the queue are terminated, including print, fax and LAN fax jobs.
NOTE: Overwrites can also be performed on a per-job basis, immediately after each job has been processed, using Immediate Image Overwrite. See the Related Items below for additional information.
CAUTION: The machine should not be in Diagnostics mode when the overwrite is started. (The Touch Screen indicates a status of "Diagnostics Mode". This mode is used by Customer Service Representatives when servicing the machine.)
Do not power off the machine while an overwrite is in progress.
To perform an On Demand Image Overwrite from the Control Panel:
  1. Access the Tools screen. See the Related Items below for additional information.
  2. Select [Security Setting].
  3. Select [Image Overwrite Security].
  4. Select [On Demand Image Overwrite].
  5. Select the [Standard / Full Overwrite] button to switch between the two options, and select the required option.
  6. Select [Overwrite Now].
  7. The Overwrite Confirmation screen will be displayed. Select the [Overwrite] button to begin, or select [Cancel] to cancel the On Demand Image Overwrite. The machine will be taken offline and will be unable to receive any incoming jobs. The Image Overwrite will proceed to overwrite all image data on the hard disk.
    NOTE: If Embedded Fax is installed, all Embedded Fax compact flash data will also be overwritten.
  8. When the overwrite is complete, the On Demand Image Overwrite completion screen will be displayed.
  9. Select [Close]. The Disk Overwrite Confirmation Report will print. This details the status and time of the overwrite. The Network Controller will then reboot and network functionality will be unavailable for several minutes.
    When the machine has rebooted, verify that the overwrite operation has completed by viewing the Confirmation Report (under Confirmation Details). The Job Information: Status ESS Disk parameter should read "SUCCESS".
Posted on Jun 08, 2011
Error messg 016-700 Memory Full
Try this, it may be a large print job held in memory.
Press 80-0-1327 to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the print job.· Press Menu to open Stored Print and delete the holding job. · To avoid this error in the future, do the following:· Delete unnecessary fonts, macros, and other data in printer memory. · Install additional printer memory.
Oct 01, 2014 | Dell 2135cn All-In-One Laser Printer
How to clear the job status memory on the Toshiba eSTUDIO 305 Machine
if there is a username and passowrd you log in. then at the bottom right of the screen you will see a job status button. if you press it it usally opens up to the jobs list .. if not after you press it look on the top of the display and select job status or print status. the select the job you want to delete and press delete.
NOTE: if your machine has a fax you cannot delete fax jobs without doing an all reset!
Sep 07, 2011 | Toshiba estudio 305 Copier
I have a Lexmark S504 wireless multifunction printer. I can print a test page but a can't print anything from any application. The Windows print page window comes up and if you click OK it appears to...
It could be a printer driver issue. Please follow the steps below to fix the problem.
First, clear the print queue from any stuck print jobs. You can do the steps mention - going to Services and stop the print spooler, delete the files in the spooler folder and then restart the service.
Second, delete the existing Lexmark Interpret S405 printer driver. On your computer, go to Start menu > Programs > Lexmark > Uninstall. After the uninstall process, reboot your pc when prompted.
Third, visit the Lexmark website to download and reinstall the Lexmark Interpret S405 printer driver. Select the version of your Windows operating system. Download and execute the file. Follow the instructions on your computer screen.
After the reinstall process is successful, try to print again to verify that the problem is fixed.
Sep 07, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Cannot change the offline status of my HP printer. It will print a diagnostic page. Also a job is stuck mid-deletion and will not go away.
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
May 25, 2011 | Office Equipment & Supplies
Installation was successful but when attempting to print "wirelessly" printer status says printer is offline.
Go to system settings and select the 'Printer' option. Right-click on the printer and enable the 'Use Printer Online' function. Cancel all the printing jobs till that moment and redo the process. Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue. Check all network connections and functions. Be sure the network interfaces work properly. Turn the printer off and on to see whether the device is working properly.
Mar 23, 2011 | Office Equipment & Supplies
Deleted print job stuck in queue
Jul 01, 2009 | Dell Inkjet 720 Printer
Print status = "deleting"/ unable to print or change status
Attempt to manually restart the Spooler service.
Click Start > Click Run > Type "services.msc" (sans the quotes) hit enter.
Right-Click on Print Spooler > Click Stop
Wait until it stops and the icon (if any) on the task bar goes away.
Right-Click on Print Spooler > Click Start.
From the options, stopping and starting is usually more effective.
Let us know if you need anything.
If this information was helpful, please take a moment to rate the solution. Thank you.
May 03, 2009 | Dell 946 All-In-One InkJet Printer
I can't "delete" a document from the que
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side
window.
On the left side click stop the service and wait forthe process to
stop
Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue
then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler
folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them
depending apon how many print jobs you submitted. You will have to
resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Apr 10, 2009 | Lexmark International Z611 Printer
2,446 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
