Question about Panasonic AJ-D250 DVCPRO DV/Mini DV VCR
It acts like the heads are dirty but they have been cleaned
Sometimes the picture kind of locks up and it stops playing. It also ate a tape. I think the deck has about 4000 hrs on it.
  • 35 Answers
4000 hours is not bad for a clean machine that is fresh
they reset the drum and capstan run time meters when the machine is serviced: so you can have circuit boards that are getting tired.. The boards have lots of Surface Mount Electrolytic Can Capacitors... the parts used are rated for 3000 hours of use at 100 deg Celcius.. they last longer as the temperature goes down..
they have a chemical inside that dries up...
so the machine may need overhaul.
but an old tape can cause this, a worn & dirty pinch roller can cause this also...
Posted on Apr 09, 2009
VCR PLAY FOR A FEW SECONDS AND THEN QUITS
Dirty heads? Need cleaning. General cleaning of all internal pinchers and rollers. Sometimes the tape is at fault. Try another just in case. I think it is time for a good cleaning. Also the eject cartridge can sometimes get bent and cause misalignment of the VHS tape and the rollers, etc....
Sep 21, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
My HDD & DVD/video cassette recorder model No RDXV60KB is connected to an analogue TV by scart lead. When I play VHS cassettes I sometimes get sound, sometimes no sound, but always on the screen only...
I dont think you will be able to get the video picture to work, unless you connect a UHF lead from video to TV then tune tv into video. Digital and analogue generally dont talk to each other.
Hope this helps.
Apr 07, 2011 | Toshiba Televison & Video
It ate the tape. Got the tape out but it wants to
run a wet cleaner tape through, the playing heads and rollers are dirty.
Feb 14, 2010 | Emerson EWV603 VHS VCR
Anyone got a clue on the issue?
You should take it back to the shop again...
Jan 22, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
The picture just stopped working, as did the
I had a problem like this with another mini-DV camera (Canon GL1) and I took care of the problem.My first thought is to use a head cleaner tape (dry head). It sounds like you have a dirty video head. DON'T try to use anything else, don't stick anything into the head or tape area. No liquids like alcohol with a q-tip, din't stick you finger in there (oils) and NO METAL. You don't want to scratch the head, even a q-tip, Kleenex, plastic, wood, cotton, t-shirt will scratch the head (and lenses). If this doesn't work, you may need to have it cleaned in a shop. Good Luck!
Dec 28, 2009 | JVC GR-D870 Mini DV Camcorder
I have certain movies for my grandchildren. There
I assume the picture after viewing your "certain movie" you have a snowy type of picture with sound? This is because your "certain movie" will have a bad section or worn section of tape & is making the heads dirty. Is there a part of the "certain movie" that gives wavy lines or the picture breaks up? If a tape is constantly used it causes the oxide coating of the tape to flake & dirty your heads. You could try a head cleaning tape although these sometimes do not do a thorough clean.
Jul 01, 2009 | Philips Televison & Video
Colored, pixilated bars appear during playback
It is very common when the magnetic heads got dirty. Buy a Mini DV cleaning tape, follow the instruction clean the heads by playing the cleaning tape for a while. Record NEW video and playback to test.
Please know if you play the old video recorded buy the dirty heads, you may not get clear picture, because here is not correct data recorded on the tape.
Apr 09, 2009 | Canon ZR90 Mini DV Digital Camcorder
Cassette player is eating tapes
Hey there.
Cassette head cleaners generally only improve the sound quality on playback. This problem sounds more like something mechanical; I would open the player and check out the capstan and rollers. If they are dirty, clean them with a mild soap and water solution, (carefull to not get it too wet). Also, as for the tape deck in your vehicle, OEM systems are notorious for eating and destroying cassette tapes.
Let me know how this goes over,
HortonA!
Mar 22, 2009 | Audio Players & Recorders
I have an old Sony Hi8 Handycam model CCD-TR705E. Have not used it for about 4 years and decided to upload tapes to DVD via a DVD recorder. Worked fine for the first 5 hours of film then suddenly picture...
Try to use video head cleaning cassette one more time and check. Problem still exist then....
There is a very special cassette used to clean much dirty video heads calls Lapping Tape.
This is provided only to Sony Service Centers.
You need to contact nearest Sony Service Center.
Oct 06, 2008 | Cameras
VWM-950
I suggest you get the Tape path cleaned up. Could be dirty video heads or a dirty Control Head. Use a good 'wet' type cleaning cassette.
Jul 03, 2007 | Sanyo VWM-950 VHS VCR
Panasonic AJ-D250 DVCPRO DV/Mini DV VCR Logo
125 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
