Question about Logic Dbx1002 1000 Watt 2-channel Mosfet Amp Car Stereo Power Amplifier
Protection light stays on - Logic Dbx1002 1000 Watt 2-channel Mosfet Amp Car Stereo Power Amplifier
800a4 stays in protect mode
Generally thats a sign of a shorted output device, either a bipolar transistor or mosfet. Also ground faults can trigger a protect light.
Feb 03, 2013 | Rockford Fosgate Punch 800a4 Car Audio...
The protection light is lit as stays lit and i have no sound coming out
if the protection light is on its an hardware failure
the protection unit will not let you power on the Amp
need to take to service
if you want to fix the amp let me know
ecrdn@yahoo.com
Jack
Oct 18, 2010 | TOA Electronics P-924MK2 Amplifier
Protection light stays on won't power up
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 25, 2009 | Diamond Audio Car Audio & Video
What does it mean when the red protection light illuminates
Hi the protection light comes on when there is a problem within the amps. circuitry. Generally speaking the protection light normally comes on when powered up while the amp checks all of its voltage rails so that they all lie within a specific tolerance, when all have been verified to be in spec. then the protect light goes out & the power light comes on. If the protect light stays on then a fault exists within it's circuitry. Cheers, acbva.
Nov 14, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Kiccker ZX200.4 the protection l,ight stays on
disconnect all the speakers from it.. turn it off and then on again, if the protection light is still on your amp has gone out and id take it to a pro to get it fixed. you might be better off getting a new one though.
Nov 05, 2009 | Kicker ZX200.4 Multi-Channel Amp - 140W ZX...
Mxa422 protection
Outputs are fried. Try disconnecting your speakers and see if it still goes into protection mode. If it does then you A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
May 24, 2009 | Lanzar MXA422 Car Audio Amplifier
SONY TA-N77ES POWERS ON BUT PROTECTION LIGHT STAYS
dry joints are common in sony (and others), needs a tech repair\visit
Apr 05, 2009 | Audio Players & Recorders
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Hi i am matt
If the protection LED lights only after the remote voltage is applied (head unit is switched on), the amplifier likely has shorted output transistors. If the protection LED remains lit without remote voltage applied, the amp may have other problems.
Does the protection LED light with no speaker wires connected to the amp and no RCAs plugged into the amp?
Jun 22, 2008 | Car Audio & Video
My amp is on but the protection light stay's on!!
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
Feb 28, 2008 | AudioBahn A2801Q Car Audio Amplifier
Logic Dbx1002 1000 Watt 2-channel Mosfet Amp Car Stereo Power Amplifier Logo
Top Logic Car Audio & Video Experts
xxxxxx xxx
Are you a Logic Car Audio and Video Expert? Answer questions, earn points and help others
