Question about GE DBXR453EV Dryer
I'M TRYING TO REPLACE A SQUEEKY PULLEY
I HAVEN'T FIGURED OUT HOW TO GET THE BACK OFF MY GE453 DRYER SO AS TO GET TO THE PULLEY FOR REPLACEMENT. MY OWNERS MANUAL DOESN'T SHOW ANYTHING.
  • GE Master
  • 3,361 Answers
The back does not come off.
Unplug the dryer.
Remove the top. Then the front panel. Then the front support. Then the belt. Then the drum.
Probably not a squeaky pulley.
Probably a bad drum bearing.
Posted on Mar 11, 2009
Haven't started it since 6/13/08. Tried for IRENE,went through step by step but pull after pull and no start. In 08 added stabilizer ,but now fuel smells bad. Book says clean carburetor;see engine...
Robin/Subaru post all their engine stuff on their website. If you poke around you should find a PDF owners manual, parts manual, and the service manual. Service manual should have what you need. Definitely drain all the gas, clean spark plug, and change oil as well.
http://robinamerica.com/industrial.aspx
Sep 05, 2011 | Coleman Powermate Subaru 5000W Portable...
Whirlpool dryer drum doesn't turn. Hear fan motor and gas ignition but drum doesn't move. Tried overide switch on door to verify the drum doesn't move. I am looking for the owner manual but I...
the belt broke,you can buy a kit with the belt,rollers and pulley,change out everything and you'll be good to go.next time send the model number.good luck.while you have the dryer apart,vac out all the dust and lint and if you have a shop vac put it on blow and blow the motor out and clean out the duct that the lint filter slides into,also if your vent line is a long run remove it from the back of the dryer and blow it out with a leaf blower if you have one.
Sep 03, 2011 | Whirlpool Dryers
Whirlpool model 110.88752792 dryer runs but does not heat
Concerning the Kenmore 11088752792 model where the dryer spins but does not heat. I had that problem a few years ago with the same model.
I replaced the fuse (part No. 3399849 about $10.00) and the thermostat (part no 3398128 about $25.00). Dryer worked fine the first try.
FYI. Today, I'm searching for what makes the dryer squeak when I came across your issue (though 6 months since you posted, but I figure there are other Kenmore stack-able owners out there searching for a fix). I haven't taken the dryer apart yet but have ordered the dryer belt, rollers, pulley (a package deal with RepairClinic) and the felt bearing/seal. May as well do a full replacement of the likely components that are causing the squeaks and not spend any more time going through trial and error repairs.
If you haven't already, the dogs on your agitator are probably due for replacement as well. RepairClinic has an agitator package deal with replacement dogs and seals.
Jul 14, 2011 | Kenmore 94802 Front Load Stacked Washer /...
I have a Kenmore Gas Dryer (model 11087471810) that threw its belt. I have the replacement belt and know how to replace that. When I opened the bottom of the dryer, I noticed the Idler pulley sitting at...
The idler pulley/tensioner fastens into two slots in the base of the dryer to the left of the motor . The belt goes around the drum then through the idler to the motor pulley ,you have to make a loop with the excess belt and feed it through the idler pulley, i normally pull the plastic pulley towards the right side of the dryer to give enough belt to go around the motor pulley then let the plastic pulley rest on the backside of the belt. do not turn the drum too much as you may pull the belt back off .
May 13, 2011 | Kenmore Dryers
Dde 5100ralwh dryer belt replacement, got new belt but wont get enough tension to spin ,how to adjust tensioner
There is no adjustment on tension pulley. Sounds as if you haven't got belt on right. It should show you how belt loops around pulley on the package the belt came in. Also you might want to check to be sure you have the right belt.Hope this helps.
Apr 29, 2011 | GE Dryers
Where does spring from pully go
The spring will attach to the frame of the dryer.
Hook your spring to the pulley and then try to attach it to the frame of the machine moving it to different locations on the frame, just remember it will have to stretch a little to attach so keep that in mind as you mentally try to hook it to the frame.
Look very carefully at the bottom of the dryer frame, it will show a very slight wear mark, and that will show at which point to attach the other end of the spring.
This is a FREE answer, Please Rate Me
You can also purchase a owners manual for the dryer to assist you in this project...and future projects with this dryer
Sep 26, 2010 | Amana Dryers
Can't put the serpentine belt back on has to much slack
You have it routed the wrong way, there should be a routing diagram under the hood
Apr 04, 2010 | 2000 Jeep Cherokee
Frigidaire dryer drum liner
yeah, i think there called "drum glides" www.partselect.com type in your model number and you if they have that dryer in the system, then breakdown of the dryer will show, multiple diagrams. And look for the glides that are supposed to go there...hopefully this helps
Jul 31, 2009 | Dryers
Kenmore Elite Driver Belt
just remove back cover ..install belt on small motor pulley first then work around drum pulley while turning large pulley try spinning by hand first to verify belt is tracking in center or close to center of large pulley
Jul 22, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
214 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
