Question about Motorola Mobility Mfv700 7-inch Digital Frame With Video-in-picture And Wireless Dect
Cant get the camera to sync with the frame - Motorola Mobility Mfv700 7-inch Digital Frame With Video-in-picture And Wireless Dect
How is the strobe activated (ikelite A35)
It works from the flas on your camera. It will only sync to your camera as along as the ixus does have no pre flash feature.
Sep 23, 2009 | Ikelite Substrobe A35 w/ Arm and Tray f/...
How can you test a camera before use to be sure the flash sync is working properly.
Set camera up and aim at a blank wall. Place flash on camera, fire off test shots with camera set to flash sync speed and lens set to wide angle (eg 18 mm), ensure flash matches angle of lens.
You will probably have to turn auto focus off, so that camera will fire, after taking photo/s use review to ensure that you have a nice even coloured piece of wall.
Any problems either with camera sync problems or flash coverage will show up in the test shots.
Camera sync, will show as part of the frame only exposed, for example you may find a horizontal line approximately 1/3 to 1/2 of frame with a proportion of the frame dark.
If you have flash "drop off" you will find the corners of your frame will be dark, you need to ensure that your flash angle specified on the flash and the focal length of the lens match.
Hope this helps Ian
Jul 21, 2009 | Cameras
Only partial picture on frame
it could be a shutter problem. however if it is only when using a flash it would be sync. for flash photography most cameras have a shutter speed that they sync at normally 1/60
May 26, 2009 | Minolta Maxxum 5000 35mm SLR Camera
FLIP: playback is frame by frame (jumpy) and... voice not in sync
i have a mino that only started doing this when it was upgraded via the usb. any help?
Feb 23, 2009 | Video Cameras
When I turn my camera on it says !Frame No. Full. I cant do anything with it though. I cant download the photos to make room. My husband thinks that it is not reading the card but reading the small amount...
You go into the menu. You choose Set-Up. Then you go to the Frame Number. It is probably on something like CONT. Change the setting to something like RENEW.
This is the answer for all the FujiFilm cameras.
--toydollz
Jul 11, 2008 | Fuji Cameras
Cant sync with pc
Try using a card reader to copy the photos over?
Oct 30, 2007 | Canon IXUS i7 Digital Camera
Canon SD 700 IS Movie Sound Issue
This is because of low light and low frame rates in the camera. It records the sound on time but the picture delays. In the camera's video menu, choose a higher frame rate to help this a little. Honestly though, If you want to shoot better video get a video camera.
Sep 14, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Motorola Mobility Mfv700 7-inch Digital Frame With Video-in-picture And Wireless Dect Logo
23 people viewed this question
Top Motorola Mobility Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Motorola Mobility Photography Expert? Answer questions, earn points and help others
