Question about Kenwood Audio Players & Recorders
Problem WITH Kenwood A45 hifi amp
THE PROBLEM I HAVE WITH MY KENWOOD A45 HIFI AMP IS WHEN I TURN IT UP IT CUTS OUT
  • 4234 Answers
SOURCE: hifi speakers
An ohm meter can determine only if the coil is open. For an 8 ohm speaker (impedence), the resistance measurement will be around 6 ohms. Why do you think these need reconing? Are they noisy?
Dan
Posted on Mar 18, 2008
  • 518 Answers
SOURCE: aiwa xrm98 hifi need the remote model number for this hifi
I think your remote's part number would be RCZAT04 and you can get the current substitute from HERE.
Hope that fixed Ya...
Geno
Posted on Mar 28, 2008
  • 319 Answers
SOURCE: hifi
Unit obviously has circuit problems, Have serviced
Posted on May 07, 2008
  • 319 Answers
SOURCE: connect a kenwood amplifer to a graphic equalizer
There are several ways to hook up a EQ to amp. If you have a tape monitor unused, you can plug tape-in of amp to 'out' of EQ.
Plug tape out of amp to 'in' of EQ (both channels). When you engage monitor on amp, EQ will work.
Posted on May 30, 2008
  • 22 Answers
SOURCE: I cannot find replacement user manual for my
try the www.keenwood.com they have manauls you can download
Posted on Mar 27, 2009
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
I have a kenwood vr506 amp . the remote no longer works.i have bought a one for all universal remote and need the code for the kenwood amp.
setup codes for cd players - HiFi Remote
www.hifi-remote.com/hag/setup_codes.htm
Sep 15, 1999 - If you are unsure whether your universal remote uses 3 digit or 4 digit ... SETUP CODES FOR AMPLIFIERS ... 0078 JVC 0331 Kenwood 0356 Linn 0269 Luxman 0165 Magnavox 0269 ... GE 0240 LiteTouch 0084 Lutron 0318, 0597 One For All 0167 .... 0048 may require TV code 0093 for volume and mute.
vcr set up codes - HiFi Remote
Feb 16, 2015 | One For All Televison & Video
Connect tv to hifi speakers
It doesn't lokk like your TV has an analog out for your Kenwood system. It might have an optical out but unless the Kenwood has optical in then you'll need to upgrade to a Home theater system with HDMI.
Feb 03, 2015 | Samsung Televison & Video
Need the 4 digit code for a kenwood vr-405 reciever with my kenwood rc-ro509 remote..stop working?
Here are some remote codes for Kenwood Receivers.
The codes are as follows: One of them should work
0027, 0077, 0313, 0186, 0314, 0356
Here is a link to a web site that has universal codes for remotes.
http://www.hifi-remote.com/ofa/codes-amp.shtml#amp
Hope this helps,
Best Regards,
Mark
Jan 27, 2011 | Kenwood VR-405 Receiver
How do i connect them
I connected the red & white audio leads to the line out sockets on the equalizer and connected them to the tape rec sockets on the amp..
May 29, 2009 | Kenwood Audio Players & Recorders
RIGHT HAND SPEAKER, DISTORTION.
First switch the speakers over to make certain it is not the amp that is the problem.
If the speaker is still playing up on the other channel, then I would look around at a new set of speakers. They can be any that you like the look of as long as they have a power ratting at 40 watts or above each. The amp says it can take 6 to 16 ohm speakers. I would go for 8 ohms as they are more common.
Jul 03, 2017 | Kenwood NV-600 CD Shelf System
Kenwood XD V757 System Protected
check the speaker wires are not shorting out
Dec 11, 2008 | Audio Players & Recorders
Vintage Stereo Connection ???
Hi spanky
Where to start :) I am excited thinking about them :p You got 2 totally cool pieces of classic vintage gear there in the C2 and the Marantz. I have a C2 preamp myself (gathering dust but wont sell it cos its excellent) and the marantz would be totally cool to have(but then I am a little biased towards 70's vintage marantz). They ruled the roost in HiFi amps throughout that decade.
Because they are both integrated amps, you could use them as standalone systems with a pair of speakers, and just plug your favourite gear into them. If you just wanted to run up a nice sounding HiFi, I would sell the kenwood gear and just keep the Marantz. The Kenwood kr1100 has the edge in power, so if it is grunt you are looking for use that. Because vintage sound is all about stereo, you only really need an integrated amp to get great results.
the specs are
# Kenwood Model Eleven G (KR-11000G) Receiver
120W per channel min RMS, both channels driven, at 8 ohms from 20 to 20.000 Hz with no more than 0.03% total harmonic distortion.
Dynamic power output 440W at 4 ohms
Power bandwidth 5 Hz to 70.000 HZ
Frequency response 5 Hz to 100.000 HZ -1.5dB
Signal to noise ratio 115dB
The marantz is a little lower in power at 75rms a channel, but will have the sonic edge in vintage sound over the kr1100. Look them up on ebay and you will find that they do have some value to collectors and people seeking nice tone. There is an 1152 for sale here for AU$900
Best bet is to fire up the 2 integrated amps,and see how they are going. Run them for several hours to be sure there is no strange noises and crackles. Then decide if you want power or finesse.
You could also run both amps from the C2 preamp by connecting to the Amp in connections to the rear of the integrated amps.
happy to talk to you more about it, hit me with a Fixya if my advice was helpful to you. I would keep the marantz, use that and sell the rest and buy some nice speakers:)
regards
robotek
Jul 20, 2008 | Audio Players & Recorders
Connect a kenwood amplifer to a graphic equalizer
May 28, 2008 | Audio Players & Recorders
168 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
