Oki c110 error 0500 - Office Equipment & Supplies
0500 error dialta cf 2002
open front door lay on your back look for the small hole on the right side touch the small switch with a screwdriver to reset the machine must be on
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 16, 2014 | Minolta DiALTA Di520 Laser Printer
CALL SERVICE (0500) what does it mean ? how to solve it ?
The users manual says when you get this error to reboot machine and if the error doesn't go away the problem can only be fixed by an authorized service provider.
Dec 28, 2012 | NEC Oki Mc160N A4 Colour Multifunction...
Can i reset the drum unit for 1690 mf
Yes You can. I will make a video or a tutorial soon.
May 15, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Ricoh 5510nf 0500 error
cleaned toner spilled inside and replaced toner ,turned off and on and the error messege went away
Mar 11, 2008 | Computers & Internet
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
Service Call 020 Fatal Error
Error 020 is a ROM dimm error, could be as simple as reseating/replacing Rom Dimm or a expensive main PCB, you need to get hold of a oki dealer, contact oki to find closest OKI repair agent.
www.oki.com
Jan 08, 2008 | OKI C9300 Led Printer
32 people viewed this question
k24674
jasbo
jasbo
