Question about Hardware & Accessories
Elect. pto wiring diagram troy bilt mower #17af2acp766
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
  • 376 Answers
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
Posted on Jun 19, 2009
  • 297 Answers
SOURCE: Replacing Drive Cable on 05 Troy Bilt Self Propelled Lawn Mower
It is a pain in the ***!!! but not impossible to do it your self.
Posted on Aug 16, 2009
  • 279 Answers
SOURCE: Troy-Bilt Mower is running real slow.
If you can, check the flywheel key. If it is bent but not quite broken, it can cause slow operation. To do that, take the starter off the top of mower. Take off the big nut on the flywheel. Find a nut of the same size and place on the thread you took the nut off, but only a few turns. Hold the flywheel with one hand, lifting a little, and tap the nut with a hammer with the other hand. The flywheel should come off. Look at the key, it holds the flywheel to the shaft. If it is bent or broken, that is the problem. Replace it and go about your day! Good luck...Lee
Posted on Sep 25, 2009
kel1guy2002
  • 3740 Answers
SOURCE: how do you tighten the control cable on a Troy Bilt mower?
Usually near the end of the cable there is a squeeze clamp on the side of the cable. Losen the mounting screw (DO NOT remove it) and slide the cable in the direction that will expose more cable. Tighten the mounting screw and test the control. It is really pretty simple.
Thanks for using FixYa.
Kelly
Posted on Apr 10, 2010
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
What is the Function of the pto control
It is to supply power the electric clutch that drives the mower deck.
If not functioning then the switch, PTO clutch, or wiring is not working properly. Note on some ZTRs when both handles are in reverse then electric clutch is disengage for safety.
Oct 06, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
After running for a while my Troy Bilt RZT tractor Colt ZT42 PTO stops working
pto going out or stater going out run till it does then replace i the red neck saya it the pto replace if you cant live with it till burns out
Aug 31, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt
It thinks that the PTO is on. Do you have two different key positions? If so try both for a temp fix. If not it's probably a linkage or switch problem.
Aug 02, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Troy bilt troubleshooting
Check under your deck you could have something that is keeping your blades fro turning.
Aug 01, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Remove pto
Assuming it is the electric PTO you are asking about, they are mounted to the bottom of the crankshaft. There is 1 bolt up thru the center. Find the power wires running to it, and unplug them, should be fairly close to the pto. Then take out the bolt, and the clutch should then slide down and off. You may have to remove the mower deck to get good access.
Jul 06, 2014 | Troy Bilt 22HP Hydrostatic 46" Riding...
42" Troy Bilt zero turn PTO switch
I would first look under the machine, check the wires leading to the pto clutch. There should be a connector/plug, make sure it is clean and plugged in completely. Also, check the wire harness grounds to the frame. Otherwise, you'll have to check the switch, power going to the switch etc. Usually, they are wired thru the safety switch harness so, could be a bad saftey switch, or bad pto switch. You'll just have to start testing wiring.
Jun 26, 2014 | Troy Garden
Mower runs but blades aren't turning
You can get help at both of these places:
http://troybilt.custhelp.com/cgi-bin/troybilt.cfg/php/enduser/std_alp.php
http://www.mowersdirect.com/technical-support.php
Aug 03, 2009 | Troy Garden
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
