Question about Electrolux EW1200i Front Load Washer / Dryer
When my washing mashine is not in use it fill up gradually over a
It fills up over a few days. it is ten years old .
  • jamesbond086 Mar 11, 2009
    is it nessery to remove tub. thanks for help
  • 11,896 Answers
I believe there is a leaky valve that shuts the water on and off, Not the one on your house. Which you really should shut those off to. You would have to remove the top and back panel of the washer, remove the tub to be able to get to the pump and valve to replace valve or rubber washer.
If possible, you should shut house water valves off that go to the washer. They also have little rubber seals inside that can wear out and leak.
Posted on Mar 11, 2009
  • Nate Stansfield
    Nate Stansfield Mar 13, 2009
    If the back panel cannot be removed, than yes it is necessary.
Mashine fills with water
check the program dial or settings. Put the machine off. then the water slot should close. If it does not close it is defect and you should ask a tech to replace it, or buy a new machine.
Mar 24, 2015 | Washing Machines
Wshing machine keeps filling with water
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
Aug 07, 2014 | Russell Hobbs RH1042 Frontload Washing...
My washing machine drains all the water at the end of the wash, but then slowly starts to fill back up. What is causing this to happen?
Hello cowmeag - From what you are describing, there are two possibilities: the valve assembly may not be seating properly or the Main Control board is sending voltage to the valves. If the valves do not seat properly, water will seep paste the valves and gradually fill the unit. I would recommend unplugging the unit. Wait approximately ten minutes and restart unit. If it still slowly fills, more than likely you water valve will need replacing. Otherwise, the dishwasher has a possible Main Control board failure.
Mar 08, 2013 | Frigidaire Affinity ATF7000E Front Load...
Water is no fill in mashine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washes until before rinsing and stops.
I think the problem was a bad waterfill value. removethe water from the base
RINSE/DRY = Water filling fault (over or under filling)
regards
balisonu79
Jan 04, 2010 | Bosch Washing Machines
Will only fill and drain
It sounds like the timer/controler is broken replace it. Peter
Mar 18, 2009 | Washing Machines
Dishwasher tub slowly fills with water after after completion
the internal parts of the valve are sticking open randomley.the diaphram/piston in the valve most likley have lime deposits on it due to poor water quality.you would need the water valve assembly but before you buy this part i would look where the water line goes into the dishwasher and it will lead you to the valve.remove the valve from the unit and disassemble the valve.clean all the internal parts in the valve and reinstall.75% of the time this works ,if not change the valve.
Jan 24, 2008 | Dishwashers
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Electrolux EW1200i Front Load Washer / Dryer Logo
111 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
