Question about Scotts Company SCOTTS SEED EDGEGUARD MINI SPREADER ()
Settings for fertilizer on scotts mini spreader
How to set dials
SOURCE: I have a Scott Rotary Fertilizer Spreader. When I
If the wheels turn( that is you can push the spreader easily) but the vertical shaft that spins the broadcasting plate doesn't, seems like the gears connecting the axle to that vertical shaft are worn; but if the wheels just slide along the gropund without turning then it would seem something right under the bin is keeping the verical shaft from turning. But I'm NOT an expert; I'm looking for an answer myself,
Posted on Mar 16, 2009
SOURCE: Spreader Settings
I called Scotts, and according to them the Edgeguard Deluxe uses the same settings as the SpeedyGreen 3000.
Posted on Jun 16, 2009
  • 125 Answers
SOURCE: need to apply lawn fertilizer at a rate of 5 lbs,
http://www.gardentech.com/spreadersettings.asp
this is a link which will help you. Your setting should be on 7-8 using a criss-cross distribution pattern
Posted on Sep 07, 2009
Testimonial: "thanks pal, worked great"
SOURCE: I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
Posted on Mar 21, 2010
  • 7 Answers
SOURCE: What setting do I use on the Scotts Mini Spreader?
Here is the rule of thumb to determine your spreader setting.
Place enough material in the hopper to cover 1,000 sq. ft. (Usually indicated on the bag of product, if not indicated, take pounds in bag and divide by the number of thousand square feet bag covers. Example: 23lb bag covers 5,000 sq ft, divide 23 by 5 to get 4.6lbs per 1,000 sq ft).
* Place the spreader setting on a low setting (Usually one-fourth of the spreader setting range or less).
* Spread the material over a 50 x 20 ft. area (This is 1,000 sq. ft.).
* If material is left over, they need to increase the setting.
* If they come up short, they need to decrease the setting.
* While this is not a scientific method for getting the spreader setting, it will be close.
Posted on May 17, 2010
I have a new Scotts Classic Drop spreader and an old bag of 16-4-8 fertilizer. 2,130 SF of Zoysia Zeon lawn. According to my guidance I need to spread 6.5 # of the 16-4-8 fertilizer over the entire area....
Does the product you are using list any Scotts AccuGreen spreader settings? If so, you can safely use the spreader settings listed for the Scotts AccuGreen. If your product does not list any spreader settings, please give Scotts a call at 866-465-5160.
Hilary @Scotts
Aug 27, 2011 | Scotts Company Scotts Turf Builder Classic...
I have scott drop spreader and I want how it will setting for fertilizer
Check the fertilizer bag for instructions. It will tell you the number to set it at for a drop spreader and a broadcast spreader.
Aug 14, 2011 | Scotts Company Garden
I just bought a new Scott's "Classic Drop" Spreader. I owned a Scott's drop spreader before and the recommended settings on Scott's fertilizer bags always worked great. On...
I am sorry that neither spreader performed as they should have. This is very concerning to us, and we would like to get more information about the spreaders, if you still have 1 the manufacture date would be most helpful to us. It sounds like you could possibly have an over-application of the product as well. If you could call us at 1-800-543-8873, we would be happy to discuss this with you. Stacey at Scotts.
Jun 06, 2011 | Scotts Company Scotts Turf Builder Classic...
I have lost my instructions for my hand held spreader. The numbers on the side that control the outlet of whatever is in the spreader--do these indicate the number of pounds per 100 sq. ft?
Below is a list of spreader settings. You may want to call Scotts at 800-543-8873 and verify the product you are using is able to be used in a hand held spreader.
  • For fine grass seed (blue, rye, fescue) use setting 1
  • For coarser seed (tall fescue) use setting 2
  • For light fertilizer (Scotts fertilizers at a regular rate) use setting 3
  • For heavy fertilizer (Scotts fertilizers at a heavy setting) use setting 4
  • For pelletized fertilizer and ice melt products use setting 5
Hilary @Scotts
May 16, 2011 | Scotts 71133 Handgreen II Hand Held...
I have a Scotts Turf Builder EdgeGuard Mini, and I'm using Ace turf builder (crabgrass preventer with fertilizer). What setting should I use???
I was just told by Scott's phone customer service (800-543-8873) that their TurfBuilder EdgeGuard mini can use the same settings as their "SpeedyGreen" broadcast spreader, if your fertilizer lists that one.
Apr 08, 2011 | Garden
I buy Scotts fertilizer and use an earthway broadcast spreader.
add 10 - Scotts Turfbuilder spread at # 4 on a Scotts spreader should be on setting # 14 on an Earthway spreader.
Mar 28, 2010 | Earthway "Earthway" Medium Duty Commercial...
Settings for scotts products
The bag of fertilizer should tell you on the back of the setting for your spreader. It will say, Scotts 3000, Greenway XXX, etc, with the setting for that particular product.
Dec 29, 2009 | Earthway Ev - N - Spred Model 2050p Estate...
Model 300 runs out of fertilizer
Since I didn't have a manul, I downloaded one from Scott's and used that to calibrate the spreader which was out of calibration.
Apr 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
Scotts Company SCOTTS SEED EDGEGUARD MINI SPREADER () Logo
78 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
lnbn1975
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
