Question about Toshiba DKT-2010 Corded Phone
Set the clock
Toshiba DKT 2010-SD; How do I adjust the time display? (Clock) on the display screen
  • Anonymous Mar 27, 2014
    Jabra 9120 headset connected to BHEU module on DKT 2010 SD. Customer requests the headset to ring in ear during incoming call.
  • 43 Answers
The link below should provide all the info you'll need.
click here
Posted on Mar 11, 2009
DKT-2020 Corded Phone (dkt2020sd): How do you change the display time on the DKT2020-...
Depending on the type of system you have powering the 2020,this should take care of it.
Leave the handset on hook, press intercom # 6 5 2, then enter the time of a 24 hour clock, entering 2 digits for the hour, 2 digits for the minutes, and 2 digits for the seconds – enter a leading 0 for any single digit entered,
press Redial,
press Speaker.
This must be done at extension 200 – usually the receptionist phone.
For example, if the time is 2:15 P.M., press intercom # 6 5 2, 1 4 1 5 0 0, Redial Speaker
May 09, 2010 | Toshiba DKT-2020 Corded Phone
Set clock on sd-kv550-su
There are two ways to set the clock on your machine, firstly by using the 'auto clock' feature and also a manual setup, if the auto setup doesn't work then you will need to setup your machine manually. the 'auto clock' feature will atempt set itself up and will take approx 4 mins for the machine to adjust itself. There is also a daylight saving setting which you can either have set to on or off. The auto and manual steps that I have added below have been taken from the user manual for your your Toshiba SD-V295 pages 24 - 26.
Hope this helps,
James
Auto Clock Adjustment
Preparation:
• Turn ON the TV and select the corresponding video input.
• Press VCR DVD selector to select the VCR mode.
(The VCR mode indicator will light.)
1. Connect the Antenna or Cable system.
If you use a cable box, turn it on.
2. Plug the AC power cord to the AC outlet.
3. Make sure the DVD/VCR is turned off.
If you press POWER, the Auto Clock set is not programmed.
4. Wait at least three minutes and press POWER.
5. Press CALL DISPLAY to check the clock setting on the on screen display.
6. If the clock is not set, check the antenna
condition. The AUTO CLOCK may not function properly if the reception condition
is not good.
Manual clock setting
1. Press VCR MENU.
2. Press SET + or – to select “SYSTEM SETUP”, then press ENTER.
3. Press SET + or – to select “CLOCK SET”, then press ENTER.
4. Press SET + or – to set the month, then press ENTER.
5. Set the day, year and time as in step 4.
6. After setting the clock, date and time starts functioning automatically
Apr 25, 2010 | Toshiba SD-V295
Trying to change the time on my Toshiba dkt2020-sd phone. I don't know how to do it.
FOR THE TOSHIBA DKT 2020-SD:
From main console phone (lowest extension number i.e. x100) pick up handset2_bing.gif and dial following codes:
For Time: Press "Intercom" and the numbers 652 enter the time in military format HHMMSS (HH=hours in 24hr clock, MM=minutes, SS=seconds) press "Redial".
Mar 15, 2010 | Toshiba DKT-2010 Corded Phone
How do you set the timeand date on a toshiba dkt
Please try this..
  1. From main console phone (lowest extension number i.e. x100) pick up handset and dial following codes:
  2. For Date: 651 YYMMDD Redial ----(YY=year, MM=month, DD=day)
  3. For Time: 652 HHMMSS Redial ----(HH=hours in 24hr clock, MM=minutes, SS=seconds)
  4. For Day of Week: 653 X Redial ----(X=day of week 1=sunday, 2=monday....etc.)
If won't work, try this
From Extension port 00 (usualy station 200)
  1. Lift Handset Dial #652
  2. Enter Correct Time HH MM SS
  3. Press Redial
  4. Replace Handset
Regards,
Jeep Brainy
Aug 10, 2009 | Toshiba DKT-2020-SD telephone
How to change voice mail clock in Toshiba DKT-2020-SD
You can log into mailbox 999 with security code 999997 or just 997 and press menu 8 for admin features. Your manul and guides are found here
http://guides.idacomusa.com/
Mar 23, 2009 | Toshiba DKT-2020-SD telephone
Toshiba DKT2010-SD Phone
OK, model on bottom of phone is DKT2010-SD, but I found a little cheat card in a file for a STRATA DK8 & DK16 so I used a combination of things. First pick up handset and then hit intercom button, # 652 (for time or #651 for date) and enter time in HHMMSS (hour, minute, second) format, once complete hit the redial button.
Nov 03, 2008 | Toshiba DKT-2010 Corded Phone
Having trouble with a Toshiba model, Need to fix time .
I have DKT3010, so it might be the same, to change time in mine I press Intercom, #652, HH/MM/SS #. It changes it on all of the extensions.
Mar 10, 2008 | Toshiba DKT3010SD Corded Phone
Business phone systems have one time setting for all telephones. It is s syatem programming feature and not something found in a user guide. Follow this link for information on changing the time on different PBX phone systems. http://www.tel-programmer.com/time_setting.html
Feb 21, 2007 | Toshiba DKT-2010 Corded Phone
Toshiba DKT-2010 Corded Phone Logo
370 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
