Question about Jeep 16" Boys Full Suspension Bike
Jeep bike kickstand - Jeep 16" Boys Full Suspension Bike
When I put in gear it dies what can the problem be? bad CD box?
Most motorcycles have a safety switch on the kickstand that prevents you from putting the bike in gear and riding off with the kickstand still down. If the bike turns off when you put it in gear and your kickstand is up, not down, you need to have the kickstand switch and wiring for the switch checked.
It may be malfunctioning.
Aug 17, 2016 | Motorcycles
My bike starts and runs fine until you put it in gear and let the clutch out then it dies...pull the clutch back in and runs again..is this the neutral safety switch.
You made the switch that turns on and off when your kickstand is down and the look on a bike you have just start your bike to kickstand down and let the clutch out see if it does the same thing you're describing iclean your kickstand this should be like a little pen the part that you push in to make the point, now could be alterity spray that with Goncourt degreaser kickstand
Feb 14, 2015 | Motorcycles
Engine cuts off when put in gear
Most dual sport motorcycles have a switch at the kickstand that prevents bike from being ridden with the kickstand down. The engine will turn off if the bike is not in neutral while the kickstand is down. Make sure your kickstand is all the way up. If it is, you may have a faulty kickstand switch.
Apr 21, 2014 | 2008 Honda CRF 230 L
I have a 95 CBR600f3 that won't start while the kickstand is down. Is this normal or is there a sensor that may have gone out?
Thgis is normal ... it is a safety interlock. Put the side stand in the storage position before you start and you will be just fine.
Dec 08, 2012 | Motorcycles
Bought a 16 inch rosebud girls bike. No kickstand was in the box. Are you suppose to lay it down when u are through riding?
Apparently. They come with training wheels so how would they fall over? You could go to a Bike Shop and see if they have small kickstands for it when the training wheels come off. None of MY bikes have kickstands (or training wheels). Teach her to lay it down gently on its left side.
Aug 23, 2011 | Cycling
How can a kickstand be mounted on a Diamondback Recoil?
Hi larryaw...
You can purchase the type of kickstand that bolts to the real axle and use it for your primary kickstand.
Please take time to rate me
http://www.amazon.com/Rear-Mount-Kickstand-Bikes-Chrome/dp/B001HBLEM4
Jul 27, 2011 | Diamondback Recoil Comp Full Suspension...
89 sportster kickstand bushings
What bushings in the kickstand? There are none. If the kickstand is worn out, you replace the kickstand. It wobbles in the hole in the frame. It's designed to do so. Notice that there is a "tang" on the top of the kickstand that goes into a slot when the bike's weight is on the stand. If not for this tang, you could push the bike forward and it would fall over. The "tang" locks the bike from moving forward or backward while on the stand.
Good Luck
Steve
Mar 21, 2011 | Harley Davidson XL Sportster 883 Hugger...
The neutral light never turn off, even the bike is running and when the kickstand is down the bike turns off even in neutral.2003 Buell Blast .
The neutral witch is behind the clutch and as long as it is switched on the bike will not run unless you defeat the kickstand switch.
I really recommend properly repairing the neutral light switch because taking off with the kickstand down can put you down on the pavement way too easily.
Aug 03, 2009 | 2003 Buell Blast
Kickstand kill switch inop
Connect the two wires together that goes to the kickstand it should keep it from starting. With wires unpluged it should start.
If that is the case you need a switch
Mar 19, 2009 | 1984 kawasaki Z 650
Jeep 16" Boys Full Suspension Bike Logo
54 people viewed this question
Top Jeep Cycling Experts
Michial Gueffroy
Bill Boyd
Donald Ayers-Marsh
Are you a Jeep Cycling Expert? Answer questions, earn points and help others
