Question about Kohler K-4711-0 C3-100 elongated toilet seat with bidet functionality and t
WHEN A TOILET IS NOT FLUSHED FOR A FEW DAYS, THE RUBBER PART STIC
Our guest toilets, when not flushed routinely, are flushed - the plastic circle part at the end iof the chainn the bottom of the tank sticks and doesn't allow the handle to flush. Help!
  • 252 Answers
The part is called a flapper - replace it - very cheap.
Posted on Mar 12, 2009
I have a Richmond RCN 0595A12328, MODEL 5V40-7 40 gallon water heater. Can you tell me if there is some kind of an assy. I can use on it so when a toilet if flushed someone in the shower does not get...
The water heater has nothing to do with it. You need a shower control valve that won't let the water pressure change when the toilet is flushed. Moen makes just such a valve called a pressure balancing valve. Moen L82683 Positemp Tub/Shower Valve. http://www.moen.com
Jan 07, 2015 | Water Water Heaters
Why does the toilet make so much noise filling FluidMaster 703A5B
Just replace the flush valve with another one.
Flush the water line by opening valve before attaching new flush valve
Aug 07, 2014 | Fluidmaster 507C White Flush Valve
Plumbing pipes make a banging noise after the toilet is flushed
the float valve that controls the level on water in the tank. is going bad. when they start to go bad the water pressure cause the the valve to flutter (tries to open and close at the same time.
Oct 17, 2013 | Mountain Plumbing Water Heaters
How to fix a dripping toilet
if the fluidmaster,itself is leaking, there is a rubber disk in the base of fluidmaster, replace disk. however, i can almost promise you the dripping you hear is from a bad flapper. replace with KORKY brand flapper. buy the basic black one, with no water saving gadgets on it.you will see cheaper black ones, but get the KORKY
Dec 20, 2012 | Fluidmaster S2DBL Dual Flush Toil System
Toilet does not flush down contents.
This seems to be a case of blockage within the toilet. Check the
Flushholes under the inside-rim of the toilet. they might be partially blocked by debris or deposits. If so, a Wire-Clotheshanger will help.
If the Blockage is in the drain, a Handauger might be helpful to push
blocking objects through or retrieve.
Waterlevel in the Toilet-tank could be too low. It should be about 1"
below the top of the Drainvalve in the middle of the Tank.
Aug 23, 2009 | Kohler C3-200 K-4709-96 Biscuit Elongated...
Shower gets hotter or colder when toilet is flushed.
This is typical for an installation without a balanced valve/anti-scald valve on the shower.
If you are using manual on/off valves on the shower, about the only way to fix this is to install the device mentioned in the previous paragraph.
May 03, 2009 | Rheem Tankless Hot Water Heater...
Only hot water in sink/basin when toilet is flushed
I had a customer a few weeks ago that had the same problem. When the water heater was installed they crossed the supply lines. They had the inlet as the outlet. Esentially, the water heater was plumbed in backwards. Also there could be a miss piping somewhere in the house but it would probably be near impossible to find it right now without tearing up foundations. Also check that the faucet is not plumbed backwards as well. Especially if this is a single handle faucet that you are referring to.
Apr 06, 2009 | Rheem Tankless Hot Water Heater...
When hot water is on & toilet flushed the temp drops
Check strainers and screens into the sink, at the spout and into the hot water heater. Sediment buildup could be limiting the flow which woul make the system more susceptible to pressure drop when the toilet is flushed.
Jan 05, 2009 | Rheem Tankless Hot Water Heater...
Hot Water Heater
do you have a mix vavle in line?
Nov 01, 2008 | Water Heaters
Kohler K-4711-0 C3-100 elongated toilet seat with bidet functionality and t Logo
87 people viewed this question
Top Kohler Water Heaters Experts
jdthefixer
Gene Haynes
Are you a Kohler Water Heater Expert? Answer questions, earn points and help others
