Question about Kenmore Sewing Machines
Model 19131 kenmore blue needles. what needle currently replaces the kenmore "Q" needles that can no longer be purchased?
  • 323 Answers
SOURCE: Hobbylock 774
If the needle bar is no longer available, the current needle bar can be repaired by cutting new threads in it and changing the screw. Not simple but not rocket science either.Most mechanics can do this.
sewman7
Posted on Aug 11, 2008
  • 9 Answers
SOURCE: Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Posted on Feb 21, 2009
Mimito7
  • 128 Answers
SOURCE: Necchi Heavy Duty Sewing machine model 3205FA,
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Posted on Apr 22, 2009
SOURCE: Needle breaks on my Shark Euro-pro model 361 my
Are you inserting the needle fully into clamp? You may have a bad lot of needles that werent straight. Try sewing by hand with machine to see exactly where and when needle breaks, then you might be able to solve problem.
Posted on May 05, 2009
SOURCE: Kenmore Model 16221 sewing machine
I am looking for advice on how to oil the Kenmore Model #16221 sewing machine. The manual is vague and confusing. Any help is appreciated. Thanks.
Posted on May 30, 2010
The needle is hitting the bobbin case on my kenmore sewing machine 385.1884180
Have you tried installing a brand-new needle? If the current needle is bent or damaged, it could be why it is hitting the bobbin case. If a new needle does not take care of the issue, you may need to take it for service.
Nov 24, 2015 | Kenmore Sewing Machines
My needle keeps breaking
fabric is too thick,get a bigger needle
May 18, 2015 | Kenmore Sewing Machines
How to replace needles
Your problem has been posted against the Elna 2007 mechanical sewing machine - not sure if this is your machine but it shouldn't make much difference. All domestic sewing machines have very similar needle placement.
The needle bar is the piece that goes up and down and holds the needle. There is usually a housing at the bottom with a thumb screw that is used to secure the needle. To change, turn your flywheel towards you until the needle is at its highest point. Turn off the motor or unplug machine for safety. Hold the needle with one hand and undo the thumb screw with the other. Insert a new needle into the housing FLAT SHANK TO THE BACK, all the way up into the housing, then tighten the thumb screw.
Standard domestic sewing machine needles are coded 130/705H and almost all makes and models will use this type of needle. Industrial machines are different and some overlockers/sergers will use a slightly longer needle called ELX.
The important thing is to change the needle regularly, about 4-6 sewing hours is maximum before the point starts to go blunt. If you can hear a squeaking or popping sound as you stitch, this is most likely a blunt needle. Also use the right sized and type of needle for the work you are doing. So for knits and jerseys, use a ball point needle to avoid skipped stitches. For lycra use a stretch needle coated with blue, helps with this synthetic fibre.
For wovens, use a sharp or universal point but pick the right size for the weight of fabric. Sheers, organza and fine silks, use a 60. Lightweight cottons, use 70. Medium weight fabrics use a 80 etc, right up to 110 size for coated upholstery fabrics. There are special needles for denim too as this is a very densly woven fabric so again, a blue coating helps to get the needle through the fibres.
I trust this helps you to resolve your problem.
Sep 28, 2011 | Elna 2007 Mechanical Sewing Machine
Can these needles be used with my sewing machine?
Don't know if this is helpful...but I have a very old Kenmore and 2 Brothers. I used the same needles with all 3 machines. No problems.
Apr 13, 2009 | Sewing Machines
Kenmore 19606 Auto Threader
I have this machine also. Make sure your needle has been placed the right way around w/flat of back needle to back entry port. Also raise the needle up to the highest point it will go, sometime the alighmnet is off and if this doesn't work then you may need a service call.This machine is made by Janome for Kenmore, so most Janome parts will fit yours too.
Feb 22, 2009 | Kenmore 19606 Computerized Sewing Machine
Color coded Kenmore needles
Hi there, The different colors only correspond with the size of the needle. Green is actually a size 18 (110) needles which is basically as big as they come! your best bet would be to go with a size 11 (75) or 12 (80) needle. For the Kenmore color coding it would blue or orange respectively. Hope this helps
Dec 10, 2008 | Kenmore 15516 Mechanical Sewing Machine
What needle to use
You should use a blue needle or a ball point needle for when sewing knits or synthetic fabrics.
Oct 25, 2008 | Kenmore 19233 Computerized Sewing Machine
Hobbylock 774
sewman7
Aug 08, 2008 | PfaFF Creative 7570
Sewing Machines Logo
43 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
