Question about Electrolux EOB5630 Ultrafan Electric Single Oven
No display on EOC68000 electric oven
Hello !
I have experience an issue with my brand new electric oven : after the first time I used it , the display went dead ...It doesn't display anything , anymore , not even the time :-(
Therefore , the appliance it's not usable anymore , since all the controls are controlled through the touch display ...
Thanks in advance for your tips
Ally
  • 163 Answers
Flip breaker off then turn back on after a few min.see if that resets panel.if not you will need to call and have the control module replaced.
Posted on Mar 11, 2009
My brand new Hoover electric oven FEC66.01 S is not heating fast & it takes a long time to cook anything on the electric burners. Help me.
Make sure you have the right voltage . Check your neutral wire for good contact . Then check the oven settings. 10_11_2013_8_30_04_am.png
Jul 18, 2013 | Ovens
F2 error on EOC68000 oven
Not exacltly the same oven but I got F2 error and solve it by :
1) Find error code on : http://appliancehelponline.com/whirlpool.html
2) take out the temperature sensor
3) the oven now indicates F1 error
4) measure sensor with ohm meter : should be a bit above 1080 ohms
5) clean the sensor carefully
6) put it back in the oven
fixed !
There is also a little circuit breaker with a red button in the oven. I also push it (maybe a reset?)
Mar 09, 2013 | Ovens
The control panel display is so light that it can not be read. I have a double built in oven SCD302. What can be done?
Hello, welcome to FixYa.
There are two common scenarios with these Thermador wall ovens fitting what you've described. The harness to the display from the control board is loose (not likely) or the display itself is failing (most likely).
The issue with these displays is they lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to replace the control/display kit...the display only is not available, but a "kit" is.
You can find these "display kits" at "repairclinic.com" and similar to what I've attached here...
**Your other option, and the one I recommend, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
You may find other suggestions or "band aid" remedies on-line, but in my experience this is the sure way to go. Here you'll find all the info pertaining to this option by clicking on the link I've provided below
http://www.corecentricsolutions.com/CCSWeb.nsf/published/bosch
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Oct 14, 2011 | Thermador SC302T Electric Double Oven
I have thermador double electric wall ovens and I have slowly over time lost the abilitty to read the information in the window display. I took off the face plate in the hopes that it was a simple bulb or...
You need a new display kit. The display kit has a new clock relay board and the white harness to the clock. The repair is straight forward.
Apr 22, 2011 | Ovens
The light in the display area on the top of the oven is out. We can not read the display as to temperature, etc. Oven still works. Controls beep when pressed, Just can't display anything. Thanks, whm
Welcome to FixYa.
The issue with these displays is they lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to replace the control/display kit...the display only is not available.
Regards,
Macmarkus :)
Feb 09, 2011 | Thermador SC302T Electric Double Oven
The panel went black- no display of clock, temp, etc. The oven doesn't heat up. the light weorks inside the oven
Hello, and sorry to read about your problem.
if you have tried to re-power the unit, and still have the same issue, you then have a general main board failure,
you may want to contact a service company. it takes experience to know which part is defective.
I tried to help you. Please help me and vote/rate my response thanks.
Jan 01, 2011 | Whirlpool RBD245PD Electric Double Oven
Where can I purchase a new LED display for my thermadour built in oven?
Welcome to FixYa.
The issue with these displays is they can lose their intensity over time, but also it can be contributed to the main control...specifically the transformer on the "C" series ovens, hence the only remedy is to replace the control/display kit.
I'd first suggest checking the main control if you feel you are capable, this is how...
1) Turn the breaker or power supply to the oven off while servicing...saferty first ( though you will need power to check the transformer, this is where an experienced tech may be necessary, you'll need to decide )
2) locate the control board behind the display ( this will require either moving the front panel or the top panel behind the display...in the plenum )
i.e.
Then identify the PCB/control board...
The large arrow identifies the main control, the small arrow is the transformer location on the board
3) Remove the control or place it at a vantage point you can perform the following voltage checks, this is where some experience or electrical knowledge comes in handy...
i.e.
If the values listed in the test chart all are o.k. then you need a display only...if not you'll need the control board. ( Before you ask, I don't know of any transformer supplier...but then you're gambling nothing else is defective on the control anyway, not worth it in my opinion, that's your call )
Now to answer your question about availability though, one can find these "display's" at "repairclinic.com" for around $225USD and includes what I've attached here...
The "PCB" or control as it is referred to as well is also available at said location for around $175USD, it will include this...
Regards,
Macmarkus :)
Dec 31, 2010 | Thermador C301U Electric Single Oven
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
LED Display fading
As noted in solutions to other Jenn Air ovens, this is often solved by replacing the capacitor labeled C3 on the circuit board that contains the display. Oven heat apparently causes it to fail over time. This is a solder connection to the circuit board. Not hard if you have any experience with this kind of soldering it is straightforward.
Seven phillips sheet metal screws to remove panel assembly, plus two electrical connectors. One ribbon connector from touch panel to board, then four 1/4 hex sheetmetal screws to remove circuit board from touch panel and metal frame. Then soldering iron.
It did work on a 40300 dual unit, which is same as this model except for cosmetics.
Capacitor is 35 volt 68 microfarad. Radio shack has 100 microfarad, which one report says works. Radio shack doesn't have a 68, but they do have 22 and 47 which mounted in parallel give 69, which is within tolerance. That's what I used. The capacitors cost $1.29, less than 1% of the cost of a new circuit board.
Jan 15, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
The electrical panel does not light up
I'm afraid you are going to need a new display board. Not very hard to change but a pricey item. Have seen this problem a few times. Good Luck!
Oct 05, 2006 | Jenn-Air WW30430P Stainless Steel Electric...
Electrolux EOB5630 Ultrafan Electric Single Oven Logo
511 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
