Question about Hifonics BXI 1606D Car Audio Amplifier
Hifonics BXI1606D repair?
My amp one day suddenly went into protect mode. I troubleshot it and found that the problem was blown MOSFETs. This is the first amp i will repair on my own and i found the problem, but i have a different problem. The MOSFETs are prtected by a metal plate that i cannot remove. Can I just cut the plate off from the heatsink? or is there a special tool used to remove this plating? if u need to see a pic pls let me know and i will email you with a better description of what I am talking about.
  • Angel Granados
    Angel Granados Aug 09, 2007
    THANKS GUYS I WILL TRY IT OUT AND LET YOU KNOW WHAT HAPPENS
  • Angel Granados
    Angel Granados Oct 04, 2007
    THANK YOU very much for the information it was very helpfull. i sure hope i can help you if you have any questions in the future.
    Novelist:
    Champion:
  • 219 Answers
There are two types of metal clamps that are in common use on these type of amps. One of them you can just pry up and off of the heat sink and the other is clipped into a groove at the top back of the heat sink. This is the hardest one to remove and put back on. If there is a small square hole at the top of the clip then you have the hard to remove kind. You must counteract the sprind tension of the clip by sticking a tool (perhaps a small pair of needle nose pliers) into that square hole and pry DOWN (not up) in order to unspring the part that is clipped into the heat sink. Be careful you don't snap off the end of your tool. It takes quiet a bit of pressure to unclip it. You might use a small flat tip screw driver to pry up on the part that is clipped to the heatsink at the same time you are prying down at the square hole. This is not a pretty process and it is just as hard to put it back on after the repair. Maybe even harder. If anyone knows of a better way to do this please let me know too because these clips are a royal pain in the butt to deal with and I sure wish I knew of a better way to do this. Maybe the manufacturer has built a special prying tool that will do it much easier, but I've never seen one. Good luck and be careful you don't break the clip while prying because that opens a whole 'nother can of worms.
Posted on Aug 03, 2007
  • 113 Answers
There is an easier way. this can be made from bicycle spoke smaller angle is about 3/16 inch . slightly sharpen tip not too much.
Posted on Aug 09, 2007
  • oscar herrera Aug 09, 2007
    heres how.
    ok guys let me know how it went
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
Amp Protection Mode
TRY DISCONNECTING IT FROM THE BATTERY FOR ABOUT AN HOUR. SEE IF THAT HELPS.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_ec38c09da1ae48dd
Nov 17, 2013 | Car Audio & Video
My alpine Mrd-1005 has been best amp ever. But the other day it all of a sudden started blowing fuses on the amp and the current protecter mode kicks on.. as long as I keep volume down in works but as soon...
make sure there is equal amps on the fuse under the hood and at the amp...also make sure to never mount your amp to anything metal....wood only! hope this helps, mine did the same thing
Sep 04, 2011 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
Protect mode
Protection circuit.
Checek the wiring of the amp and speakers, don' forget to look for shorts at the speakers. Make sure no wires are touching each other
Apr 30, 2010 | Volfenhag 1600 WATT CHROME AMP AMPLIFIER 2...
Amp is in protect mode
If you have'nt fixed your amp by now I thought I'd tell ya a couple of things why it's going into protect. The basics. Blown subs, bad power suply or mosfets, and blown output transistors/mosfets. Still need help let me know. I repair amps for a living and i'm the cheapest you'll find and honest. I also give the longest warranty. I'm tired of other people rippin people off on repairs. Let me know.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Apr 24, 2010 | MA Audio HK401SX Car Audio Amplifier
I accidently put my power wire into ground terminal and ground wire on power side for a second and it sparked. The amp power light still comes on but the sub barely movees. Is there any way i can fix this...
No,your amplifier probably has damaged power supply transistors as a result of improper power connections,contact eric @ Capital Audio & Electronics repair 850-339-1130 in Tallahassee,Fl-we repair all namebrands & all models
Mar 17, 2010 | Alpine MRD-M1005 Car Audio Amplifier
My amp turns on and pumps once then it stops bt the amp is still geting power
First try unhooking the speakers and see if it continues to go into protect mode. If it does'nt then your speakers are running to low of ohms required for that amp causing it to go into protect mode. If it still goes into protect mode check your ground, might have a voltage problem and check voltage going into amp. I have read the manual and this amp has advanced circuit protection. So if all I have asked you to do and it still goes into protect mode then amp is faulty and has some output transistors shorted or power supply mosfets shorted. Let me know what you find. But you need to do what I have explained to narrow the problem down. Good luck, Keep me informed. I will be glad to help you thru this. I also have a business of repairing car amps and you will not find anyone cheeper. So if you want it repaired and you feel you can't do it, just send it to me and I will repair. If you decide this E-mail me at:skinnman33@gmail.com and we can discuss it in more detail. Just a thought to try and help you out. I have many customers that send me there amps and I repair them and ship them back. A few come from this site. Let me know
Jan 31, 2009 | Lanzar VIBE286 Car Audio Amplifier
The protect light stays on
is your amp grounded well?
are all of your fuses fine?
connections to stereo?
if all else fails you might have blown your amp like mine, you can see about getting it fixed but i just found another one.
how many watts is your amp? how much does your sub need?
Nov 18, 2008 | Pyle - Elite: 2 Channel 1800W Elite Series...
Blown car amp repair (Lanzar Opti 150 stereo bridgeable car amp)
its better to change them all. than to change 1 or 2 mosfets, bcuz simetimes it affects the other mosfets. and please check your speaker or maybe there is an resistor, capacitors, or a relay malfunctioning in that area.
Jan 18, 2008 | Car Audio & Video
Car Audio & Video Logo
507 people viewed this question
Top Hifonics Car Audio & Video Experts
Mike Duncan
Mike Duncan
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
