Question about Epson Workforce 610 All-In-One InkJet Printer
My Epson Workforce 610 ran a sheet of paper half way through the unit, then stopped and stuck. I pulled the paper the rest of the way through the unit, but then I get an error to turn the unit off, th
I have had no problems with this unit since I have purchased it. It has performed extremely well, and I hate to have to replace it. Any suggestions?
TJ4722
  • 54 Answers
SOURCE: Epson workforce 600 continue to
If this message appears when you turn the printer on it will need a repair, this will be down to a sensor fault.
If this message appears when you try to print Check you are using the correct paper type and size settings, on the printer if being used standalone or via the printer driver if using via a computer.
Also try using a different paper type and brand ideally Epson paper as it is an Epson printer. If the fault continues the printer will need a service.
As this printer was released this year you should be covered by some form of warranty, contact Epson for a service.
Posted on Dec 13, 2009
SOURCE: epson workforce 600. says it has paper jam but
FIXES FOR EPSON RX600 PAPER JAM
Posted on Jan 18, 2010
SOURCE: keeps saying paper jamed when I try to print
On the Epson website it is confirmed that the Epson WorkForce 610 will not recognize transparency media. It is just the way the printer works; if it can see through the media, it doesn't think it's there.
However.....you can tape a sheet of white paper to the non-printable side of the transparency, and it prints just fine. I put two strips of scotch tape on either side, top and bottom. Works great. It's kind of a hassle, but better than not being able to print transparencies at all!
Posted on Jan 09, 2011
hattinghbr
  • 214 Answers
SOURCE: epson workforce 610 carriage flys to the right when turned on and say's paper jam. the only option is to shut off the printer
check if you open the printer door. there is a plastic strip with black lins on. clean it or check if it is in place.
Posted on Nov 08, 2011
SOURCE: Epson Workforce 610 had a paper jam. Removed the
I had a similar issue. After ordering a new printer and being told by the epson tech that I need to buy a new printer, I attempted once more to fix the printer before giving up on it.
I noticed when starting the printer up, the container that holds the ink cartridges would move all the way to the right, stop, and then the error would occur.
Eventually, I held the cartridge housing up and forward a little when starting the printer. This fixed the problem, as the cartridge housing was able to get past its stuck point and continue on its journey.
Hopefully this helps someone
Posted on Oct 02, 2012
Why is my printer in error state
Can you Clarify which type of error are you facing ?
Sep 21, 2014 | Epson Workforce 610 All In One Inkpr...
How do I remove the Headers on the Epson Workforce 610 so I can clear a blocked header?
Head cleaning solution here http://www.fixyourownprinter.com/kits/epson you need to figure which is the right one for your unlisted printer. maybe look at which other ones use the same ink
May 02, 2014 | Epson Workforce 610 All-In-One InkJet...
I have a Epson Work Force 610 series printer that had a printer jam, how can I reset it?
There may be a scrap of paper still jamming the printer. It needs another look
Mar 24, 2013 | Epson Office Equipment & Supplies
Torn paper- how can I disassemble epson workforce 610?
Before you do a complete teardown, use a flashlight to examine every possible point in the paper feed path where the paper is jammed. There may be an easier way to clear it. In some cases I have had to clear a paper jam bit by bit using tweezers.
Oct 15, 2012 | Epson Workforce 610 All-In-One InkJet...
I keep getting a paper jam error and there is no paper in the printer. It prints one page and then gives me the error
usually there is some small piece of paper stuck somewhere, exploratory surgery with a LOT of LIGHT is the next step.
Jun 03, 2011 | Epson Workforce 610 All-In-One InkJet...
Epson workforce 610 prints croocked
I would try holding the printer upside down and gently tapping.
There maybe something stuck in the paper in slot
Aug 02, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson workfroce 610 prints crooked
then you have to adjust the paper, it might be that the printer pulls one side of the paper in first making it look tilted.
Keeps saying paper jamed when I try to print
Jul 22, 2010 | Epson Workforce 610 All-In-One InkJet...
Epson Workforce 610 All-In-One InkJet Printer Logo
20 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
