Question about HP Photosmart 3310 Printer
Paper tray won't go back in
I have a HP 3310 and the darn paper tray wont go back in, it will if I force it. The paper pick-up seames to be hanig low. Any one know how to get to it?
  • IggyV Mar 15, 2009
    No paper, it looks like its haing up on some black guides near the back.
Hello i am STEVE
Posted on Feb 27, 2014
Go to the back of your hp photosmart printer and there is a small compartment.
open it up and there will be a piece of paper there pull it out and your paper tray should go back in.
by aamir ahmed
Posted on Mar 14, 2009
OfficeJet Pro 8600 will not pick up glossy photo paper from the tray
I tried everything that was suggested on the HP forum but then tried something not reccommended there and it worked. Not only remove tray 2 from the printer properties but force the print to tray 2, when you this it sets the Quality from normal or Best to Custom. Once I done that it worked... Just disabling the tray 2 is not enough.
Mar 26, 2012 | HP OfficeJet Pro K8600 Printer
My HP Photosmart 3310 will not pick-up A4 glossy photo paper in the main tray. 6x4 works fine in the photo tray
Your printer might have opening area for clearing paper jams, also on that area there are some rounded parts that do actual picking-up of paper. Clean those parts with some non-agresive cleaning agent and try again.
Mar 06, 2011 | HP Photosmart 3310 Printer
Printer making crunching noise when printing. trouble picking up paper from main tray. keeps asking for paper to be loaded in tray, when its full. help D
It is a hardware problem.Your printer roller & paper sensor are not working properly. So pls checked it from service center
Oct 13, 2009 | HP Photosmart 3310 Printer
HP 3310 All In One
Don't know if this will help but. I had a HP printer that would not feed the really heavy weight photo paper, I just backed down a couple weights and it worked fine...
Jan 23, 2009 | HP Photosmart 3310 Printer
Hp 3310 paper feed
Take off the back of the printer - there is a door running almost the full length which has a latch. Using regular rubbing alcohol and a Q-TIP(R) cotton swab, clean the little rubber rollers which grab the paper from the tray. The rollers you need to clean will be low and on the left as you look at the back of the printer and they are about 2 inches inside the printer. There are 2 of them. Paper dust builds up on them and they fail to grab the next sheet of paper, causing the error message. Works every time!
Sep 14, 2008 | HP Photosmart 3310 Printer
Constant "load paper in tray" error even when paper is loaded.
Contacted HP CEO, office getting some interest now!
Re bad paper feeder Did not use main tray feeder until now!
Nov 30, 2007 | HP Photosmart 3310 Printer
HP Photosmart 3310 does not recognize paper in tray
This is usually do to a sensor, your correct on that, thers usually a plastic piece that indicates theres paper and its broken or worn.
The other thing is that it may be the little rubber grabber is worn and not grabbing the paper, so the printer thinks thers no paper because nothings going through. These parts can be orderd but are usually costly depending on the printer. If its under warranty, take it back.
Also, check the trey and make sure it isnt a I.D.10.T error and you just set the paper to legal or something. I've made that mistake before.
Nov 27, 2007 | HP Photosmart 3310 Printer
Paper in 3310 HP
You have a possible paper jam or foreign matter in your roller area or feeder area, get a torch and thoroughly check inside unit, near carriages, roller and paper feeder.
Aug 17, 2007 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
251 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
