Question about Troy Bilt Tb70ss Gas Trimmer
How to replace clutch clutch assembly.
May I please have service manual instructions on how to access and replace the clutch assembly for troybilt trimmer model TB70SS?
Cutting head will turn sleightly when the engine is reved up, but stops when exposed to load.
Thanks! Appreciate it!
Bill D. Adams
4 Suggested Answers
  • 2929 Answers
SOURCE: I have a TROY-BILT String Trimmer model TB70SS and
Click Here For Your Manual.
If it takes you back to your model number & serial number, simply enter your model number and any random number for the serial. You will be able to access the manuals from there.
I hope this helps.
Posted on May 06, 2010
  • 102 Answers
SOURCE: TB70ss clutch
Check to see if there is any material collected around the base of the head, around the tube that provides the energy to spin. It may cause the power to be diminished a great deal, so that must be cleaned away thoroughly. Check to see if you can spin the head freely by your hand, without the motor being on. If not, it may need lubrication down the indide of the power shaft. A light grease would do that, or even a heavy oil poured down the shaft, but not too much.
Posted on Sep 20, 2012
  • 38 Answers
SOURCE: TB70ss Trimmer runs but does not turn the string
Remove the angle drive gearbox near the string head and spin it to see if everything is moving properly. You may have stripped the gears out of it.
Posted on Sep 23, 2012
2005 Yamaha yZ 85 replace the clutch
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
clutch assembly question YZ85 2006
How to replace clutch in Dirtbike
YAMAHA YZ85 Owner Service Manual
YAMAHA YZ85 Owner Manual
Dec 29, 2017 | 2005 Yamaha yZ 85
Why is my clutch so ******* my 1985 Kawasaki kx80??
does it have an actuating pin, adjust it at the engine side after releasing the lever end to slack
Sep 18, 2017 | kawasaki Motorcycles
I replaced drive belt on troybilt mustang rzt shortly after electric pto clutch stopped engaging
Moist likely you failed to reinstall PTO clutch correctly as it sound the anti-rotation device wasn't installed. When you started the engine it would spun pulling the wiring apart. Hopefully just connector came part; otherwise, you might need to purchase a new PTO clutch assembly.
May 12, 2015 | Mustang Garden
I am in need of an owners manual .pdf for a troybilt 6000W generator model 030475A
Wiring diagram (link below) and a link to Troy Manuals PDF Manual Web Archive - requires serial number to access
A good site for manuals or seeking of Free User Manuals and Owners Guides ManualsOnline com
Dec 11, 2014 | Garden
Fuel pump assembly removal. I need to replace the Fuel pump in my 1999 Buick Century, I believe it is a custom model. I have the replacement pump already, I simply need the instructions to remove and...
Go to GM website and search for Service Data for your year/model vehicle. Then Contact GM and request access to Service Manuals regarding your vehicle.
Jun 30, 2009 | 1999 Buick Century
How to remove(unscrew?) centrifugal clutch assembly from engine shaft of TB575SS troybilt 4-cycle weed trimmer?
Remove spark plug and insert some cord into the spark plug hole to freeze the crank shaft. This way you can unscrew the clutch from the engine .
Jun 23, 2009 | Garden
Need Instructions on 2003 Hyundai Tiburon Clutch Replacement
Go to and register (vehicle by VIN). Afterward, you'll have access to technical information (manuals, wiring diagrams, service bulletins, etc) about your vehicle.
Jun 12, 2009 | 2003 Hyundai Tiburon
I need to replace the transmission drive belt and need instructions
There's actually a Troy-Bilt Pony riding lawn mower as well.  If yours is like ours, a model 13AN77TG766 [URL:], it doesn't actually have gears but rather a variable-speed pulley.  The lever on the dashboard actually controls how high the brake pedal will go, while the brake pedal controls the position of the variable-speed pulley, which controls the effective gearing ratio.  That's how it can go at any speed with the engine still going at the same rate and without having to disengage a clutch.
So perhaps your mower is engaging the parking brake too early (page 17 of our manual).  The other thing I can think of is grass in the variable-speed pulley.  To check that, remove the spark plug and the battery (7/16-inch socket).  Then move the shift lever through its full range and check the shaft of the variable-speed pulley (part 63 on page 34) for debris, both above and below the loose plate thingy.  (You should be able to turn it quite easily if you put the forward/reverse lever in neutral.)
Hope that helps!
Jun 01, 2009 | Troy-Bilt Pony Garden Tiller
My Troybilt Snow Blower wheels have locked up
Just found the same problem with mine.  The bearing on the gear shaft is frozen.  To replace these, follow the instructions in the manual to replace the friction wheel, then tap out the bearings in the side of the case, you'll probably find one frozen up.  As long as you're there, might as well put in a new friction wheel.  Mine is looking pretty worn after fighting the bearings all winter.
Apr 11, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Starter rope on Troybilt TB575SS
try removing the starter housing, inside will be a large white or black wheel, visually inspect to make sure the componets are not damaged and that nothing jamming it. try using a lithium spray grease to lubricate the componets. if it still doesn't work the inner coil is probably damaged or came off track. it is very difficult to fix or replace this coil. i suggest taking to your nearest service center but if you would like to try it yourself, let me know and i will give you further instructions.
Oct 04, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Troy Bilt Tb70ss Gas Trimmer Logo
584 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
