Question about GE Kitchen Ranges
Ge jbp55 range control module repair - GE Kitchen Ranges
How do I remove the cooktop from a GE Profile Dual Fuel J2S968SHSS? I need to replace the Spark Module. Where is that located? I already replaced the wiring harness but cannot get the cooktop to re
Check in the control panel. GE sometimes puts the spark module up in the control panel. I would look there first. Sometimes they put it in the side panel.
Nov 20, 2014 | GE Kitchen Ranges
GE Gas Oven and broiler not working
No, there is a "hot-point" ignition for each but they are both controlled by the ignition module, easy fix, follow the wires (2) from the Broiler ignition point.... they will lead you to the module. More then likely it's wire connection came apart.....
Mar 15, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 range has an f8 error code and keeps beeping.
Component failure within Electronic Range Control (ERC) effecting temp processing circuits. Replace the ERC. Here is that part to order.
Jun 03, 2013 | Kitchen Ranges
Does anyone know how to find a very old part? Do I have any chance at all? Where can I look? I got the dreaded F1 error, so my control panel is shot and I need another one for my GE JSP26 slide in (Part...
The cheapest place if to find out from a repair store where you can source one from a scrapped unit. Also try to find out from the GE service dealer if there is any units which are to be scrapped and so the module can be salvaged.
Aug 11, 2011 | GE JSP26 Electric Kitchen Range
F7 code keeps coming up on the digipad screen. timer goes on and off by itself. even when unplugged and then plugged back in, still happens.
The F7 code is due to a stuck button on the touch panel or a bad control module. You will need to unplug the range and remove the back panel. The first thing you will need to check is that the ribbon connector that goes from the touch panel to the control module is seated correctly. If it is found seated correctly then you will need to remove the ribbon connector and try cleaning the contacts with an eraser then re-install the connector and power the range back up. If the error code comes back then you will need to determine if the touch pad or control module is defective. You can do this by disconnecting the ribbon cable and power the range back on. Then wait 24 hours and see if the error comes back. If it does then it is the control module(ERC) and if it does not then the touchpad is the problem. Doing this work will require you to remove the back panel of the range. Make sure that you do not work on the range when it is plugged into the electrical outlet. You can be injured or worse if you attempt to make repairs on the range and you do not know what you are doing.
Apr 07, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The control panel is frozen on a GE JPB77
Replace the oven control module (TO8 control) may be the name of the part you need. It conrols all oven functions, including clock and timers.
Mar 28, 2009 | GE Spectra JBP78 Electric Kitchen Range
GE model JKP13GOP2BG control panel faulty ( F1 code)
Often times when someone makes an attempt to "repair" a control, it does not hold up. Replace the entire control. Don't waste your time. You will also get a year warranty on a replacement control.
Dec 13, 2008 | GE JSP69 Electric Kitchen Range
F1 fault
Here are the fault code for GE:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Nov 07, 2007 | GE JSP26 Electric Kitchen Range
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
