Question about BlueStar Miller Bluestar 185 Dx Gas Weldergenerator 907269
How to get the resistance values for a miller blue star welder generator serial# Lk03007R
Need the resistance values for stator and rotor!..
I have a Miller Bobcat 225. Engine and AC side OK, no welding output. Looking for a check list to troubleshoot with. I am able to do check with multi-meter. Just don't know values that are normal
Most common problem for no output is the brushes, you should also have approx. 3 ohms resistance across the slip rings. Can get you more info, but will require the serial number of the welder.
Dec 06, 2016 | Miller Welding Tools
How do I pull the motor from the generator assembly?
You have to put a wrench on the rotor where it sticks out of the bell housing and another wrench on the flywheel with a tool that miller makes to bolt onto the flywheel. Break it loose and then pull the engine and rotor as one piece off the welder. Then unscrew the rotor the rest of the way and remove it.
Feb 09, 2015 | Miller Bobcat 250 OHV Welder Generator...
I am looking for a starter switch for a Miller Welder. Blue Star 2E, Serial # JA438286
Miller switch part # 011611 you can order through your nearest Miller dealer.
Oct 11, 2014 | Welding Tools
How to test portable generator stator for short in windings
You will need what the factory resistances valuea re supposed to be, cold. Then use a high quality ohm meter with 3 decimal places, disconenct all wires off the stator. Check each wire with a meter to the ground frame, if there is any value, stator is shorted. Then check between stator wires ie L1 L2 and compare resistance value with factory values.
Oct 02, 2014 | Briggs & Stratton Electrical Supplies
Serial number miller AEAD 200LE JF 885778
Check this out:
http://www.ebay.com/itm/MILLER-AEAD-200LE-CONSTANT-CURRENT-AC-DC-ARC-WELDING-GENERATOR-GAS-POWERED-/310368057796?pt=BI_Welders&hash=item484360b9c4
Jan 13, 2012 | Miller Welding Tools
Wiring diagram for miller bluestar welder ser. JE817646
http://www.millerwelds.com/service/ownersmanuals.php?model
If you see a model that is close in description in the Blue Star models, such as a "145" the wiring diagram should be close if not the same. Otherwise select from the list the Blue Star with the same engine type as yours.
The If the tag is not damaged, and truly a JE series, you can download all the Blue Star manuals to find the one that has your serial number in the range. Miller is good with manuals, but sometimes the cross reference to just serial number does not work.
Dec 17, 2011 | Welding Tools
I have a generator that does not produce any volts. I replaced the brush block because it was bad with no help. I took resistance readings of the rotor and stator. Are these in spec?? briggs and stratton...
As long as you have continuity through the stator and rotor windings, and no continuity from the windings to the core, you should be good.
If the brush block was replaced due to it being defective, take a look at the diode and capacitor regulator as well. Using a multimeter, the diode should indicate continuity in one direction, infinite resistance in the other. If you get this, then replace the capacitor. If not, then replace the diode, and likely the capacitor as well.
May 28, 2010 | Briggs & Stratton Electrical Supplies
BlueStar Miller Bluestar 185 Dx Gas Weldergenerator 907269 Logo
46 people viewed this question
Top BlueStar Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a BlueStar Electrical Supply Expert? Answer questions, earn points and help others
