Question about Kenmore 44932 Front Load Washer
Kenmore Front Load Washer 417 411 42000 leaks
The bolt on the bottom of the drum in the middle is wet and water drips from there. Does the drum need to be resealed and how hard is that to do? Seems like taking it apart could be an all day job. Any Suggestions.
  • 15,935 Answers
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
I need the replace blade/plastic middle for a Marvin fan model 91800
Okay I am sure you now know never over tighten into plastic. Here are 3 choices. Tap to next size bigger bolt threads. 2nd choice if metric thread bolt go to next bigger standard bolt or visa versa. Just the slight bigger size will do it. And changing the pitch of the bolt threads to will help too.3rd choice if 2nd choice didn't work or you want to help it more. Wet thread hole with water. Add gorilla glue into hole don't over do it. Wet bolt with water. Slowly twist it in till it bottoms out and DO NOT TRY OVER TIGHTEN. Just snug it. Used gorilla glue with same bolt on vent fan and it still works. Although I don't let it on when not there. If fan can cause damage if it comes off. Do first choice and still had small amount of glue to threads.
Jul 11, 2016 | Cars & Trucks
Well it could be clogged. I that case machine should be open at the bottom and take down the hose that connects to drum.
Here there are multiple problems it is probably electronics. Unless you find some cheap replacement that machine is gone.
Apr 14, 2016 | Speed Washing Machines
I have a leak somewhere.where could it come from?
check the pipes from the water main and the pipes in the machine could be a seal has gone
Feb 19, 2016 | Kenmore HE2 Plus Front Load Washer
Can water be held in drum or under drum... my water is off but its still dripping underneath.. for 2 days now also can overloading cause this to happen?
The design of this washer has the tub (outer container) in two half's that clip/bolt together. It is likely that the seal that seals the two half's has failed. You need to confirm that this is the source of the leak. Others have reported as you the same condition and have confirmed that this seal will leak.
The red arrow points to part number 10 seal.
It you can confirm by observing the source of the leak that it is the seal the part is available and this can be repaired!! The repair is not for the faint of heart and requires lots of experience and finesse.
If you cannot confirm that the tub seal is leaking then check the front door seal. The front door seal is not as difficult to replace and there are many videos showing the replacement. Your observation that the leak continues is an indication that the residual water in the tub is slowly leaking. If the washer has frozen then it is possible that it might have been related to the leak. I expect that the load size is not the root cause.
Check you owners warrantee this leak may be covered by an extended manufactures warrantee.
You might live with the situation for a little while finding a tray to catch the water. Others have reported mold forming on the tub.
If you are not strong of heart to tackle DIY, but fat in wallet you may seek to get a repair estimate. Compare the repair cost with a replacement machine.
26039797-cmpppu1nchs2wy552ovfnv1h-5-0.jpg The following video makes the replacement seem so easy!
Washer Tub Seal Replacement Frigidaire Front Load Washing Machine Repair...
Jan 05, 2016 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
I have a WSXH208 ge front loader It started to fill was and then in the middle the water pumped out but did not finish and clothes were sopping wet, Drum stopped spinning. what could be wrong
all front loaders will not go into high spped spin if there is water in the tub.You should first remove the bottom panel and check the water pump for blockage.Some units have a sscrew style filter to catch debris befor it enters the pump impellor.when you unscrew the filter make sure you have a wet vac handy.
Apr 02, 2013 | Washing Machines
Kenmore front loader tub fills with water when not in use
your water fill valves are leaking severely,you should see water dripping in there all the time if its this bad and your clothes should still be wet,not damp even after a good spin after the final spin
Mar 23, 2010 | Kenmore 43142 Front Load Washer
Bissell Pro Heat 9200 dirty water dripping out
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
Mar 20, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My 2001 Town Car has water on the drivers side floor. It is both front and back, but under the seat is dry.
you need to get car on a lift and look under it there should be four floorpan body plugs that are loose, rotted or fell out. and water for the road is now getting yor carpet wet.the plugs are on the middle of floor for ds. ps. rear and ft. you will need to reseal them or replace. hope this helps
Feb 10, 2010 | 2001 Lincoln Town Car
Water remains in machine after a wash, clothes dripping wet. What could the problem be?
I would say that the filter is need of cleaning.
If you cannot find a filter located at the front bottom right of washer, remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or bstruction here as well.
Hope this helps.
Dec 18, 2009 | Hotpoint Washing Machines
Internal leak on a kenmore top load washer
Yes, very likely is a bad water inlet valve allowing water to leak past it into the drum. Really not a difficult repair with a little help.
Go here for:
Kenmore Washing Machine Parts
appliance parts, help & more
Sep 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 44932 Front Load Washer Logo
163 people viewed this question
Sal De
 Brian Main
Brian Main
