Question about Apple (M4775ZM/A) Print Server
Wireless print server....all jobs freeze after 6-12% processed
Unable to print
  • 611 Answers
Check the ip address ,drivers, software, and the wireless devices
Posted on Mar 14, 2009
Good day i'm having a freezing problem with my printer if i send 10-100 prints it processes then prints half the job and then freezes with processing written on the screen please help!
Dear Sinclair
The freezing occurs due to two things.
1- when you command print file size is more than the buffer RAM of the printer. ( it will solved choosing page no. selection to print). If there is option to increase the RAM of printer, may be up graded.
2- Fixing temp. when exceeds predetermined temp. it takes a short time may be neglected.
Thanks.
Mar 18, 2015 | HP LaserJet 5200 Printer
Tip
Installation CD for the print server
If you are having trouble going through the setup process on the installation cd do the following:
  1. Disable any encryption settings on your wireless router.
  2. Disable MAC filtering.
If these features are enabled during the installation setup process, the wireless features will not work unless you go into the admin settings of the print server by typing the IP address into internet explorer. Type in the correct encryption settings.
Linksys has a provision in the setup software to key in the correct encryption however the software doesn't put the information in properly. This will cause the wireless not to work and allow the print server to work only when it is wired to the network.
Encryption settings have to be entered through the administration settings of the router by typing in the IP address of the print server using internet explorer.
on Jul 20, 2008 | Linksys WPSM54G Print Server
Can I wirelessly network my hp pec 1350 with a belkin wireless g all in one print server
The Belkin Wireless G All-In-One Print Server lets you easily add an all-in-one printer to your wireless or wired network. It features 802.11g technology that makes sending print jobs faster than ever, and includes a memory buffer that handles your graphic jobs effortlessly. The Print Server is so easy to install that you'll be printing in minutes. Simply connect your Print Server to your Belkin Wireless Router and run the Belkin Easy Installation CD. Next, attach your USB printer to the Print Server and load yourprinter drivers onto your computer. You are now free to print, scan, fax and readcard media* wirelessly from around the home or office. The Print Server also works flawlessly with wired networks through its integrated Ethernet port. Compatible with most USB, network-ready printers, the Wireless G All-In-One Print Server from Belkin delivers even your most data-intensive print jobs with maximum speed and reliability.
*If your all-in-one device has a card-reader slot.
Instructions:http://www.belkin.com/pyramid/documents/external/F1UP0002_EN_QIG.pdf
Nov 21, 2012 | HP Psc 1350 All In One Printer Scanner...
I can't print pdf files from the internet, I have to "save as"1st
Sometimes the file name assigned to a pdf is not compatible with our printer's memory. For example, if the file name includes brackets [ ] or other punctuation, or is very long, the printer won't recognize it. One print job that stalls will hold up the entire print queue, so delete your job from the queue.
First, look at the file name displayed in the print server's list of print jobs. The same file name also appears in the top blue bar of your Acrobat pdf display. Are there brackets, per cent signs, or other punctuation marks in the file name?
Dec 28, 2009 | Microsoft Office Home and Student 2007...
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Connecting the WGPS606 to Dell AIO 962
Try installing a lower end printer to the same port. For example HP LaserJet 3.
Mar 30, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Unable to setup wireless print server with wireless router
The issue was the wireless print server not properly connecting to my home network and thus being unable to see my modem/network. This was because my linksys wireless print server generates its wep key with a different algorithm than the Motorola surfboard SBG900, this also explains why when I was using my old linksys wireless g router, things worked without any issue (same wep key algorithm). Once I figured out how to manually configure the print servers wireless settings and manually enter the wep security settings I was able to connect to my network and the configuration found the print server and I was able to finish setup.
Nov 27, 2008 | Linksys WPSM54G Print Server
Canon imagerunner c3200 stuck in processing data
If you don't print via a server,you can turn the iRC3200 off...then back on and that will clear the print jobs.
If after doing this it STILL has a traffic jam in the print que when trying to print the same document then stop sending THAT particular document as the document has a formatting issue and NOT the printer.
If you DO use a print server then you(or your I.T Professional) need to go to the server and clear the print jobs from the server.
Aug 06, 2008 | Canon imageRUNNER C3200 Copier
Computers & Internet Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
