Question about Hitachi Deskstar 7K250 80GB (hds722580vlat20) 80 GB Hard Drive
Show me how to set jumper on the hds722580vlat20 ata/ide drive as slave
2 Suggested Answers
josema_sv
  • 485 Answers
SOURCE: how do i set hds722580vlat20 ata/ide as a slave
Since it's an IDE hard disk, you'll have to setup disk jumpers, please check the following image:
josema_sv_0.gif If you want more information please see the installation guide at the following link:
http://www.hitachigst.com/tech/techlib.nsf/techdocs/4DD4DCCA11DE5EB186256D6A0061C8A8/$file/Installposter.pdf
Posted on Feb 21, 2011
What are the jumper settings on the drive for the following? Cable select Slave Master
For Slave/Master set up most hard drives have a little diagram on them showing you where to put your jumpers for master and where to put the other one for slave. All hard drives are different. But on your diagram it should say "MA" for master, "SL" for slave and "CS" for cable select.
For Cable select you have to set jumpers to cable selected which should be on the diagram on your hard drive. You will need an 80 conductor IDE/ATA cable. The master conductor is at the end of the cable and the slave conductor is in the middle.
Mar 25, 2011 | Computers & Internet
How do i set hds722580vlat20 ata/ide as a slave drive
Feb 21, 2011 | Hitachi Deskstar 7K250 80GB...
Need IDE jumber settings.
There is a little jumper block on the rear of a DVD. by IDE connector. on the case above there will be a Table marked . Master: Slave: CS. Now, you must set the jumper as to your drive's position. IE: Master or Slave, Master is on the plug at the END of the ribbon, the Slave is on the "Other" one. Accordingly the Master has the Master Jumper ON, the Slave the Slave Jumper ON. CS is Cable Select. It isn't all that used.
Feb 11, 2010 | Plextor 52x32x52 PX-230A Internal CD-RW...
Have rs480m motherboard need the 2pin sequence to hook up the hard drive ''e-machine t6520''
I assume you are looking to connect another hard drive in your computer.
Most desktop computers have two IDE controllers.
The 1st controller will have the "C" drive set to Master (MA) and there maybe another drive CD or DVD drive on the same IDE cable, if so the drive will be set to Slave (SL) or if you intend to install a drive on this cable.
The 2nd. IDE controller and cable can have hard drive or CD/DVD drives too but the drives must be set to either Master or Slave - BOTH drives in the one cable CANNOT be set the same.
Most CD/DVD drives have a label showing the jumper setting for Master (MA), Slave (SL)and Cable Select (CS).
You only need a single jumper and it is inserted in a vertical position.
There are a group of 6 pins (3 columns of 2 pins) next to the 40 pin IDE connector.
The Slave setting is usually the middle set of pins.
Nov 29, 2009 | E-Machines T6520 PC Desktop
I need to dump the contents of a Quantum Fireball Plus LM onto my Dell Studio Desktop (Vista). Do I need to set the drive jumpers to make this an auxilary drive before booting up my Dell?
it just depends in what position you hook it up ...on the cable ...if you have a normal ata /ide master ...just get it like it is ...but if you will set in a slave position you have to set the pin for it in the same manner .....
the default for the master is in the first fromn the left ( near ata ) one jumper in ds position ...first from the left ...
FOR SLAVE : IS THE 3RD FROM THE LEFT ...IN THE PK POSITION SECOND NEAR THE POWER
but I understood that this position really do not have a working value and the setting can be plane no jumper at all for slave ..
Nov 13, 2009 | Quantum Fireball Plus LM 30 GB ATA-66 Hard...
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Maxtor ata 80g drive jumper settings to slave?
PDF File
Work around, Set both drives to cable select, then the ide channel flat ribbon cable will determine which is master and which is slave.
But to answer your question, no jumpers= slave
Apr 14, 2008 | Computers & Internet
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Installing a ata hard disk.
I dont quite get how you've got them connected so I'll tell you how I'd do it.
First of all, it is kind of standard to put the primary drive at the end of the cable but it doesnt really matter. I go with what ever physically works best.
Connect your 2 IDE devices to the same IDE channel (cable) unless you have 2 IDE channels then put each on their own channel or cable. Make sure you are using 60 conductor cables for each.
If both are on the same cable:
Set the dvd's jumper to slave.
Set the hard drive jumper to master
OR
vice versa.
*Some DVD burners do not like to be slave, or even on the same channel as another device.
The following is the ideal set up
If each is on their own channel (cable):
Set each to master
Be sure bios is set to auto detect for all channels, master & slaves.
** If this doesnt resolve your problem, please post a comment before rating.
Oct 17, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hitachi Deskstar 7K250 80GB (hds722580vlat20) 80 GB Hard Drive Logo
135 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
