Question about ASUS WL-530g Router
How to find who use my wireless router - ASUS WL-530g Router
    Problem Solver:
  • 9 Answers
You cant check unless they are using it at the time...you can check by logging into the router configuration
Posted on Mar 11, 2009
Which are the best Wireless Routers under $200?
Some of the best wireless routers available under $200 are:-
? Linksys WRT1900ACS Dual-Band Wi-Fi Gigabit Router
? ASUS RT-AC68U Wireless AC1900 Dual-Band Gigabit Router
? TP-Link AC1900 Wireless Dual-Band Gigabit Router
? NETGEAR AC1750 Wi-Fi Cable Modem Router
? TP-Link Archer C7 AC1750 Wireless Router
You can check and compare these wireless routers at:
Best Wireless Routers 2017 Reviews and Comparison
Jan 07, 2017 | Best Computers & Internet
How do i hook up a wireless router to a cable router
If you already have a cable router, then you don't want to use a wireless router. You will want to use a wireless access point instead.
The reason for this is that anything plugged-in to your cable router will not be able to access anything connected to the wireless router due to the NAT firewall in the wireless router.
If the wireless router has the option to make it a "Gateway", then that will fix this issue; otherwise, take the router back and buy a wireless access point instead.
As for how you hook up the wireless router to the cable router, you have to unplug the power cord of the cable router for about 15 minutes before hooking the Ethernet jack from it to the wireless router.
Once the 15 minutes have passed, you then can plug the Ethernet cable from the wireless router "WAN" port into an Ethernet port on the cable router and then plug-in the power cord of the cable router.
Once the cable router is finished syncing-up, the cable router should provide an IP address to the wireless router.
If you really have a cable modem instead of a cable router, then you won't have to put the wireless router into gateway mode.
Dec 30, 2010 | Linksys Wireless-G WRT54G Router
I get limeted access to internet
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router's SSID or the wireless network's name, To change the router's channel, To enable the wireless security on the router, Log ionto your router, 192.168.1.1
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router's firmware on Linksys
Dec 08, 2010 | Linksys Wireless-G WRT54G Router
2 routers. Can i have two routers within the same workgroup. My wireless router will not work from one end of the house to the other. I need to have more than one wireless transmitter so my laptop will...
Yes you can have the setup in your workgroup in multiple ways.
Solution1:-
The logic will be making your new wireless router to act as a wireless booster which will receive the signal from your old wireless Router and then retransmits the signal.But this needs some extra configuration on your new wireless router
1. You have to select the WDS ( wireless Distribution System) mode in the new wireless router.
2. Set the same SSID on the new wireless router.
3. In the new wireless router config page , search for the wireless signals and select your old router from that list.
The WDS mode tells the new wireless router to send/receive the wireless signal to the old wireless router.
Solution 2:-
Connect your old wireless router LAN interface to a network switch through a CAT5e UTP cable and the new wireless router to another port of the switch (use a cable which can be extended to the other room where you want the new wireless router to be placed).
Configure the same SSID you have set in the old wireless router.
Best Regards
Nov 15, 2010 | Computers & Internet
CAN I SET UP A ROUTER USING A PS3
No, the wireless card in the PS3 is just ike a wireless card in a computer. You cannot turn a wireless card into a wireless router, a wireless router is a special piece of equipment.
You need to purchase a wireless router.
Feb 01, 2010 | NetGear WGR614 Wireless Router
I want to hook up my laptop wireless with the Actiontec GT704WG how do I do this- it is my only comouter
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Nov 26, 2009 | Actiontec GT704WG Wireless Router...
I can not access the internet when I install my linksys wireless router.
Is the DSL or Cable modem connected to the Wireless router?
Nov 19, 2009 | Linksys Wireless-G WRT54G Router
Router will not go wireless. all lights come on
The "wireless" (second) light on this model does not indicate that the router's wireless features are active, it indicates that a computer is connected to the router wirelessly. If the "router" (fourth) light shows three little "radio wave" symbols, the router's wireless capability is on.
Nov 18, 2009 | Belkin (F5D8231-4) Wireless Router...
How to set up the router? can only connect to the Internet when the laptop is connected directly through the router
The wireless router needs its wireless settings configured and also the wireless card in all the laptops needs to be configured with the router’s wireless settings so the laptops can communicate with the wireless router.
Nov 15, 2009 | D-Link DIR-615 Wireless Router
ASUS WL-530g Router Logo
682 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
