Question about Uniden Cordless Phone
Phone says "out of range"
I have a Uniden DSS3455 with two extensions. Worked fine until one day the main phone that sits on the base won't let me answer as it says it's out of range and it's been sitting on the base the whole time or sitting on a table in front of the base. So I have been using one of the extensions instead, which works fine. Can I fix this? Thanks
  • lyndabarry19 Mar 12, 2009
    Will give it a go and let you know.
    Problem Solver:
  • 14 Answers
I'd try pulling the battery on the phone that is out of range and letting it sit for a couple of days. Then plug the battery back in and see if the phone activates. If nothing happens then try putting it back in the charger. My guess is if it's been sitting in the charger the whole time, the battery developed a memory and thinks it's dead.
Posted on Mar 11, 2009
Hi i FINALLY solved this problem by taking out the batteries on the phones, and unplugging them and then putting them back in.
After 2 days of trouble shooting! So this worked! No more out of range!
Good Luck
Posted on Apr 12, 2009
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
What is meant when screen says out of range
You will need to take your handset closer to the base because the signal is weak and out of range. Try locating the charging base in a more central location. If this doesn't work try this.
For more info go to this site
Customer Support
Feb 27, 2015 | Uniden Dect6.0 Digital Answering Syst W...
My uniden phone says - out of range
Uniden wxi477 out of range fix
This problem arises when the handset does not communicate with the base.
These are the steps:
1: Deregistering the handset
2: Registering the handset to base
Deregestering clears the stored (incorrect) base information on the handset.
Reregestering allows the base to assign a new ID for the handset.
Deregistering- press and hold the OFF (red button) and the # button on the handset for 5 seconds. select base unavailable and press OK. Are you sure appears. select yes and press OK. you will hear a confirmation tone. The handset will delete its own base information without trying to contact the base. It will now display MODELS VARY PLACE HANDSET ON THE BASE FOR REGISTRATION.
Registering the handset with the base- Make sure the tel. line and power is plugged into the base.
Press an hold the register button under the base (located between the tel. line and yellow power socket under the base) for 5 seconds until the red light flashes. At the same time press and hold the # button on the handset for 5 secs. You will hear a tone and It will now display REGISTRATION COMPLETE.
If it says registration failed: Retry the registration steps. Make sure the handset have enough battery power. If not charge for 15-20 hrs.
Check your connections on the base and make it is getting power.
The Steps above was my fix for the uniden wxi477 out of range problem.
Good luck.
May 25, 2010 | Uniden TRU9585 Cordless Phone
My uniden hanset stopped working. When I click on
Disconnect your phone from the wall and charger....Take out the Batteries and wait 2 secs...Replace batteries and recconnect phone ..see if this problem is still happening.
1. Disconnect Battery from handset(s)
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Heres a site for more help:http://mycusthelp.net/UNIDEN/supportkbitem.asp?sSessionID=&Inc=1093&sFilA=Product&sFilB=Model&sFilC=&FA=-1&FB=-1&FC=-1
(Copy paste to browser)
Mar 08, 2010 | Uniden Cordless Phone
My problem is I can not phone out with my phone which is a Uniden DSS3455 it seems as if it is locked. I was changing the ringing tone when it happened I must of pressed the wrong code.
try a simple reset first. just drop the charger into the base and watch the charger light. when it flickers that has reset it. if that does not work try resetting the handset by removing the battery for about ten minutes. remember to drop it into the base after you have put the battery back in to sync it with the base. if neither of those methods work which they should... unplug the base for about ten minutes.... make sure you also unplug the phone line as well. after it has reset plug it all back in and place the handset into the base again for a few seconds
Jan 14, 2010 | Uniden Lands Phones
Uniden powermax 24 out of range
Check the line comming into the main handset base. Make sure it is not cracked or your cat hasn't chewed through it.LOL This sounds like the most likley solution. Try hooking the main phone line to an ordinary old fashioned touch tone phone with a wired handset and if that is working then the problem lies in the main base of your new phone. It could be as simple as reprogramming the base.
Jul 24, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Handset out of range - message
We totally unplugged the phone, made sure the battery was charged and reset the phone as though it was brand new, in other words started from scratch. It seemed to work and the phone is O.K. now
Jan 16, 2009 | Uniden TRU9585 Cordless Phone
Uniden cordless model DC7758-4
Does the Uniden cordless phone model DC7758 have an answering machine?
Sep 30, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
450 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
