Question about Zebra LS3578-FZ20005WR LS3578-FZ Cordless Bar Code Reader LS3578-FZ20005WR, L Barcode Scanner
Ls3578- want to scan a barcode that will tab not have it autotab
How do i program the natural return or 'enter'
123Scan2 is an easy-to-use, PC-based software tool that enables the quick and easy set up of Motorola scanners.
Oct 31, 2013 | Zebra Symbol LS3578-FZ Barcode Scanner -...
Is there a way to make the scanner tab twice
Yes, the scanner can tab several times after a scan. We can email you a word doc with the solution. Contact BCTP at 888-317-3440 of fill out this form and we will contact you.
Tech Support Barcoding Technical Support
Jun 27, 2012 | Symbol LS 4278 Barcode Scanner
Hi, how do i downgrade the firmware for LS3578? Thanks
The Symbol LS3578-ER has a "single flow" frimware system. Meaning you can inly upgrade.
You may be able to contact symbol and they will create a special file for you.
Mar 14, 2011 | Symbol LS3578-ER Wireless Handheld Barcode...
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Sep 07, 2010 | Symbol LS3578-ER Rugged Barcode Scanner
{TAB} after I scan barcodes??
I just had to do this today... took me a while, but I figured it out. Download the manual from here:
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Scan the following barcodes in order and it will add a tab to the end of the barcode you scan.
Scan "Scan Options" Pg 13-6
Scan "<Data><Suffix>" Pg 13-7
Scan "Scan Suffix>" Pg 13-5
Scan "7" Pg Appendix D-3
Scan "0" Pg Appendix D-1
Scan "9" Pg Appendix D-4
Scan "Enter" Pg 13-8
You should now have a tab at the end of any barcodes you scan. Hope this helps!
Mar 03, 2010 | Symbol LS2208 Handheld
WILL NOT READ 2D BARCODES
That is correct this LASER scanner does not read 2D barcodes. It contains a long range 1D laser engine.
Light source: 650 nm visible laser diode
Datasheet can be found:-
http://www.motorola.com/staticfiles/Business/Products/Bar%20Code%20Scanning/Bar%20Code%20Scanners/Rugged%20Scanners/LS3578-ER/_Documents/Static%20Files/LS3578ER_SS_1208.pdf
If you want to read 2D barcodes you would require an imager. For long range try the Intermec SR61 it contains an EX25 imager.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 01, 2009 | Symbol MOTOROLA LS3578-ER EXTENDED RANGE...
How to add CR to ls3578
To set the scanner to do a CR you will need to scan the following barcodes:
Scan Options.
<DATA><SUFFIX>
ENTER
You will be able to find them on the product reference guide.
Me aware that if this is a wireless scanner, you may need to scan the barcode that says Send Configuration to Cradle.
I hope this helps.
Get back to me it you still need more help.
Mar 27, 2009 | Symbol LS3578-ER Rugged Barcode Scanner
Where is my barcode after I scan it?
Is the cradle connected to the pc via either usb, serial or keyboard wedge?
If so you will need to first, pair the scanner with the cradle by scanning the barcode on the cradle and second, configure the cradle properly so it transmits the data to the host.
Download the product reference guide from motorola website. You will get all the configuration information you need in there.
Mar 20, 2009 | Symbol LS3578-FZ Barcode Scanner - P/N...
Zebra LS3578-FZ20005WR LS3578-FZ Cordless Bar Code Reader LS3578-FZ20005WR, L Barcode Scanner Logo
93 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
