Question about iiyama ProLite E380S-B (Black) 15" LCD Monitor
Display settings are out of range
I was messing with my display settings and as I've set them higher than the max which is 1024x768, my screen has gone black. How do I get it back to normal?
  • 94 Answers
You going to go to safe mode and try to restore you system to the date that you not change the video settings of computer just go to start button goto accessories click system tools and click system restore
Posted on Mar 12, 2009
How to center my display in acer travelmate 5720
If your display is not centered try adjusting your screen resolution. Click Start/Control Panel and look for Display or Appearance and Personalization. Open them to open the display properties and click the settings tab for screen resolution. Set your resolution up higher. The higher the resolution, the smaller the icons, thus the more fits on the screen. Normal resolution is about 1024x768.
May 29, 2012 | Acer TravelMate 5730-6204 Notebook
When i switched on my computer,my desktop will no fit onto my screen i have to scroll from side to side with the mouse or up and down to view the complete screen.
This can happen if your display resolution settings in windows are set higher then your monitor can support. The display is meant to be set at 1024x768. You can set this by going into the control panel, select display. You will find the option to set the resolution in there,
Regards, Chris
May 19, 2011 | Packard Bell FT500 15" LCD Monitor
My Mac will not install the Digital camera Solution Disk says my screen resolution is insufficient...
This must be because you have a widescreen monitor or because you have set a screen resolution that's too low for anything.
Most programs ask for a screen resolution higher than 1024x768 (which they rarely actually need) to install.
So you can change yours to that value (or higher) for the installation and if it distorts your display, set it back to the original value later.
To see how to change your resolution, go to this site; http://www.ehow.com/how_2064940_change-display-resolution-mac-osxchange-display-resolution-mac-osx.html
After setting the resolution to 1024x768 or higher, run the installation and it should proceed with no problems.
May 04, 2011 | Canon A3300 IS Digital Camera
How to set the display settings
Make sure the video driver has been installed.
Go to Start - Control Panel - Display - click on Settings tab and change the Screen Resolution, Start with a resolution 1024X768 with 32 bit color. Increase the Screen resolution higher if required to suit your needs.
Jun 14, 2010 | ViewSonic VA1930WM LCD Monitor
I havE A VEIWSONIC Va520 when I turn it on , it brings up a screen saying out of range H-30-62 KHZ V-50-75 Hz what does this mean?
1. maybe the problem is with windows, because the refresh rate is set to an acceptable value
2. your lcd screen runs at higher hz than 60
3. you are running a resolution higher than 1024x768 15" LCD's generally can only support 1024x768 whereas larger panels support higher resolutions.
Possible solutions
1. The LCD you buy is shipped with a plastic cover over the screen which shows maximum resolution and recommended refresh rate. When you first turn on your computer press F8 to access safe mode, after you enter safe mode, configured the required setting on your lcd monitor. when you are done, reboot or restart your computer, hopefully your computer should be fine.
2. attempt to access the bios setup utility by pressing del or f2 of your keyboard after you see the initial display of your pc, if you can see it, the problem is with windows because the refresh rate is set to an acceptable value. Set it to its required settings by entering safe mode as posted on no.1
http://lcdmonitor-repairsecrets.url-Go.com
Dec 02, 2009 | ViewSonic VA520 15" Flat Panel LCD Monitor
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
Aug 25, 2009 | Hansol Computers & Internet
What should I set my computer settings to when trying to connect to my Lg 42lg30 TV
check the screen resolution from your manual, your computer display resolution must match your tv spec.
Mar 18, 2009 | LG 42LG30 42 in. LCD HDTV
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
Display Resolution
Make sure you have the correct driver loaded from the Fujitsu website. Additionally, try removing the Display Adapter from device manager and reboot. This will allow Windows to identify the "new" hardware and attempt to install. If asked, point Windows to the driver files from Fujitsu and that should fix you up :)
Hope this helps!
Sep 28, 2008 | Fujitsu LifeBook C1320D Notebook
I need to set my display settings to 1024x768 pixels or higher, i dont know how.
Start>Control Panel>Display>Settings
In this window you will see the screen resolution on the left, just move the slider across till it gets to 1024X768 and click OK
Aug 30, 2008 | Computers & Internet
iiyama ProLite E380S-B (Black) 15" LCD Monitor Logo
195 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
