Question about Marcel Drucker Diamond Accent Panther Link Bracelet Watch
D-Link DRU-350C drivders needed for Vista
Hi, can anyone tell me if they managed to find and install these drivers?
IF so where can I dl them?
Toshiba Satellite M305-S4848 SD card reader stopped working after a virus, not detected by windows
Do you see the sd card reader on device manager?
You can get to device manager by following the steps below:
  1. Click on the Start button and then Control Panel.
  2. Click on the System and Maintenance link.
    Note: If you're viewing the Classic View of Control Panel, you won't see this link. Simply double-click on the Administrative Tools icon and proceed to Step 4.
  3. In the System and Maintenance window, click on the Administrative Tools link near the bottom of the window.
  4. In the Administrative Tools window, double-click on the Computer Management icon.
  5. When the Computer Management utility opens, click on Device Manager on the left side of the window, located toward the bottom of the list under the System Tools heading.
    Device Manager should now appear on the right side of the Computer Management window.
    browse through and see if you find the device under IDE ATA/ATAPI controllers category.
If you see any splats remove it and then reboot your computer. Once it reboots it should find the native drivers and start working again.
Give this a shot!
Jan 24, 2013 | Toshiba Satellite M305-S4848 - Core 2 Duo...
I have a pure nrg athletics watch the number is pnrg79256 and I lost the manual. Can anyone help? thanks
Hi I have manual for PNRG 79249 which should work on your watch.my Email address is ronaldjlorette@gmail.com. If you still need help,send me an Email and I can tell you what to do or I can photocopy my manuel and mail it to you. Ron.
Nov 09, 2012 | Watches
Lost the battery for Fossil ES 8949 could you please tell me what battery I need for replacement
Link
Please refer to above link for the replacement of your Fossil Watch.
Suggest to contact the authorized dealer.
Thank you.
Dec 24, 2009 | Fossil AM3425 Wrist Watch
During install (Vista) I never got the message new hardware is ready to use ant find forerunner 50, waits a long time and says it cant pair
Here is the link for all Garmin Forerunner 50 manuals:
http://www8.garmin.com/support/userManual.jsp?market=67&subcategory=68&product=010-00679-05
You may need completely reset your device, but as the very first step I'd advise to check compatibility with Windows Vista.
If you can't get it all sorted, use this link for technical support:
http://www.bodytronics.com/Merchant2/merchant.mvc?Screen=HELPTECH
Rate, please.
Jul 21, 2009 | Garmin Forerunner 50 Personal Trainer...
10L02 Wittnauer watch~need band screws that connect link to link
If you can get to a watchmaker or even one of those watck "kiosks" where they mostly replace batteries or even a jeweller they may have what you need.
Jul 18, 2009 | Watches
Set time/date How??
Follow this link:
http://www.tissot.ch/index_offer.php?c=eu&l=en
Find and download instructions for your watch. Site is quite complicated, but you will find all the info you need if you've got patience.
Rate me, please.
Mar 14, 2009 | Tissot T33.1.588.71 Wrist Watch
Peugeot406hdi
It sounds like the pump may be faulty. These are not cheap ! Could be a faulty pressure sensor, loose pipe connection or blocked fuel filter. Check the fuel filter is clear of water and dirt. Check there are no visible leaks between the pump and the injectors.
Have you run it low on fuel ? It is possible to get air in the system, and as air is more compressible than diesel, the pump pressure sensor may be showing a low pressure.
Oct 28, 2007 | Watches
Marcel Drucker Diamond Accent Panther Link  Bracelet Watch Logo
Top Marcel Drucker Watches Experts
Ansel Alberto
Ansel Alberto
Tom Chichester
Ann Lily
Ann Lily
Are you a Marcel Drucker Watch Expert? Answer questions, earn points and help others
