Question about Sony Televison & Video
Location of laser lens on sony dvd player model DVP-NS700P
SOURCE: Sony DVP-NS57P all region
try thomson
Posted on Feb 04, 2008
  • 3 Answers
SOURCE: unlock region code on Sony CD/DVD Player DVP-NS57P
I don't have a solution, but I know that the one about "press Display, Top Menu, Clear, Power" doesn't work.
Posted on Oct 12, 2008
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
sony dvp-fx811 - multiregion codes wanted
Posted on Dec 21, 2008
SOURCE: How to turn off the closed captions on my sony dvd
I had the same problem so i simply turned off the CCD on the tv itself and no more captions!
Posted on Jun 12, 2010
SOURCE: need region code for dvd player sony dvp-sr200p
unlocked dvd sony dvp sr200p code
Posted on Dec 18, 2010
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Hello
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Feb 27, 2012 | Sony DVP-NS710H/B DVD Player
I am not able to play DVD and CD in my Sony DVP NS51P
Have you tried cleaning the player with a disc made for cleaning optical drives? These such units are available at retail locations such as Traget and Best Buy.http://www.target.com/Memorex-DVD-Laser-Lens-Cleaner/dp/B000P0OJ8O/ref=sc_qi_detailbutton
May 05, 2011 | Sony DVP-NS51P DVD Player
Sony ns-355 cannot play dvd-r,dvd-rw. CD-read
The dvd laser is dead. The one that reads cd is still functioning.
Aug 19, 2010 | Sony DVP-NS355 DVD Player
My colour on dvd is green and pink is there a setting
yes check the color from the remote and adjust it from there its easy and fast .
May 31, 2010 | Sony DVP-NS700P DVD Player
Sony dvp-fx810; install dvd; display says "loading", disc spins until finally stops, says "check disc". no picture at all.
You can try cleaning the laser lens.
CAUTION!! The lens is delicate! I wipe DVD lenses with ONE drop of glasses cleaner on a Q-tip and, starting in the center, wipe in circles to the outside. Do not press down! Do not force the lens side to side. It will move while cleaning but don't put more pressure than needed to move the lens 3/4 way down!
Its a cheap test to see if there is a fingerprint on the lens. (You won't be able to see it - does not take much)
If this does not help, it means it needs a laser or worse. Probably just replace the player.
Mar 21, 2010 | Sony DVP-FX810 Portable DVD Player
Sony DVP-NS325 "Cannot read disc"
there is some problems with your optical lens that is why not spinning or reading data on disc. before change the lens adjust first the two trimmer for DVD and CD adjustment for laser beam.
Sep 09, 2009 | Sony DVP-NS325 Multi-disc DVD Player
Try to play various DVD's and get "insert disc" message .
This could just be a dirty laser lens. Turn the unit on and open tray. While the tray is open unplug the unit without turning off so the tray stays open. Remove the cover and under the disc clamp is the optical pick up assembly. The lens can be cleaned gently with a alcohol dampened q-tip. The lens should look clear not hazy. If this does not help the whole pick-up assembly will have to be replaced. There are no adjustments that can be made on these, they are factory set. Go to www.encompassparts.com and click on guest log in, or http://servicesales.sel.sony.com (search is in the upper right, make sure to change drop down menu to psrt number) and use this part number A-6062-705-A to get prices.
Sep 07, 2009 | Sony DVP-NS700P DVD Player
Trey locked
There is a lock on this on the remote or end the menu system I do not remeber witch. You can unlock this software if not you need to unlock it hardware witch gets a little tedious.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 24, 2009 | Sony DVP-NS700P DVD Player
I just purchased a Sony DVD player...DVP-SR200P. Plugged it in and have no color...movies play in black and white only.
Hello cherylsacket,
Check your cables to your TV. If possible check the various cables to your set. I would suggest using the HDMI cable if your TV has an HDMI input. Remember to power off all devices before connecting your cables. If I may ask which cable are you using to connect between your Tv and the DVD player?
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 10, 2009 | Sony DVP-NS700P DVD Player
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
