Question about Casio Brand New-Fx-991es Plus - Scientific Calculator
How to calculate parallel circuit in casio fx-991ES plus
  • 8068 Answers
SOURCE: mode change
Just so that we know what we are talking about. The natural display is the display mode in which fractions appear on two lines, radicals appear as radicals, log can be calculated in any base, etc. If that is what you understand by Natural Display, we are in agreement.
To set this mode, you turn calculator ON and press [SHIFT][MODE] (setup). The option is called MathIO, and it has the number 1.
Thus [SHIFT][MODE][1:MathIO].
Hope it helps.
Posted on Oct 13, 2009
  • 8068 Answers
SOURCE: Casio fx-7400G PLUS cubic solver?
First let us repair the terminology.
  1. You can evaluate any expression (find the value of any expression for a particular value of its variable).Store a value in the variable, say X. Key in the expression and press [EXE].
  2. You can consider your expression(should not contain a relational operator such as =, greater than, less than, greater than or equal to, less than or equal to) to be a function Y1(x) = expression and graph it, or generate a table for it. You will have several values of the function calculated at various points.
  3. You can set your expression equal to 0 and find the particular value(s) of the variable (the unknown) that make the equality TRUE. That is called solving an equation.
I am not sure that it has a solver (solving an equation or an inequation) but you can always draw your expression as a function and explore the graph (SKTCH) to locate the roots (or zeros) of the functions (the values of the variable where the function equals zero.) That is called solving graphically.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Posted on Dec 03, 2009
SOURCE: how can we do linear interpolation in casio fx-991ES calculator
how solve interpolation by casio fx 991 ex
Posted on Nov 28, 2010
  • 37 Answers
SOURCE: how can i calculate log inverse with my fx-991ES
By 'log inverse', you presumably mean the inverse of the logarithm function. There are two logarithm functions on most scientific calculators. Firstly [ln], or natural logarithms, to the base e, where the inverse is e^x. Secondly [log], or logarithms to the base 10, where the inverse is 10^x.
Example 1 : ln(2) = 0.69314718 so e^0.69314718 = 2
Example 2: log(2) = 0.301029995 so 10^0.30102995 = 2
Posted on Oct 03, 2011
  • 102366 Answers
SOURCE: my casio calculator is giving answers always in fraction form. I need to get the answers in decimal form (my calculator is fx-991ES)
To convert a single answer from symbolic to decimal, press the S--D key (just above the DEL key). To have all answers come out in decimal format, press SHIFT MODE 2 to switch to the LineIO mode.
Posted on Aug 04, 2012
How i can get infinity symbol in casio fx-991es plus calculator
You can't do that on Casio fx-991es plus calculator. Usually, infinity symbol available in calculators with CAS (Computer Algebra System).
Dec 02, 2017 | Casio Office Equipment & Supplies
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
Combinations on fx-991ES
Press [SHIFT][ division key]. It is marked with nCr.
May 03, 2014 | Casio Brand New-Fx-991es Plus - Scientific...
Answers in log or ln form?
This is a good scientific calculator that can do a lot, but things in the realm of a CAS (Computer Algebra System) are beyond its capabilities.
Apr 23, 2014 | Casio Brand New-Fx-991es Plus - Scientific...
Is there a verify mode on the CASIO fx-991es plus calculator?
You should try to explore the calculator to find its capabilities. You can also read the manual. Everything is in it.
Press the Mode button, then the down arrow key. On the second page of the mode list you find 2:Verif
Mar 23, 2014 | Casio Brand New-Fx-991es Plus - Scientific...
Is it possible to solve eqn in this 82ms calculator
Sorry, It is not possible to solve equations on the Casio FX-82 ms. Try the Casio FX-115 ES/ FX-115 ES Plus, FX-991ES/ FX-881 ES Plus C.
Oct 29, 2013 | Casio FX82MS Scientific Calculator
Calculators fx algebra
The FX-991ES Plus barely handles simple operations on matrices of dimensions up to 3X3. It cannot find eigenvalues or eigenvectors.
Oct 24, 2013 | Casio Brand New-Fx-991es Plus - Scientific...
PRIME FACTORIZATION USING CASIO FX-991ES PLUS
If it does not have the FACT key, you must factor by hand: Divide by 2, then by 3, 5, 7 etc.
Apr 24, 2013 | Casio Brand New-Fx-991es Plus - Scientific...
Write your equations first, then try to use the calculator to solve the problem. If you don't know how to do it by hand, you won't be able to ask the calculator to do it for you.
Apr 19, 2013 | Casio Brand New-Fx-991es Plus - Scientific...
I have to buy Casio FX-991W Plus. No one has it. I checked eBay and the Casio web-site. I need that one. where can I get it from?
If you cannot find it, buy an FX-991ES. It is solar-powerd and it has the natural text-book display, which is a novelty in calculators.
I know that Staples carry the FX-991ES.
Hope it helps.
Nov 27, 2008 | Casio FX-115W Plus Calculator
Casio Brand New-Fx-991es Plus - Scientific Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
