Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Running High @ -10 C and should run at -20 C on coldest setting
This is Keesler Air Forse Base. were a hospital and have a Freezer of yours that's not getting cold enouff, it needs to get down to -20 to -25 degrees C on its coldest setting... I checked the fan and its working.. this is model 253.9240410 SN: S407178825 what is the next step in troubble shooting this unit... it needs to get another 10 degrees colder.
  • 1 more comment
  • raymond_wils Mar 11, 2009
    this is Keesler Air Force Base (were a hospital) and my Laboratory Kenmore Freezer needs to be down to -20 to -25 DEG ... the Fan is working, the compressor is working.. what is next to check??
    This is a Hospital and my Laboratory Freezer needs to get to -20 DEG and its only getting to -10 ... the fan is working
  • steve
    steve May 11, 2010
    A residential freezer will not get that cold.
  • 323 Answers
1. Make sure the sealing gasket is making good contact all the way around. It's pretty easy to lose 10 degrees. If it is a magnetic seal on the door gasket, it may not be sealing all the way around.
2. If it is staying that cold, everything is working well enough. Maybe you need a little gas in the compressor. Time for the service guy.
By the way, is your unit speced to be that cold full of supplies? Is the door opened frequently? minus 35 is pretty cold.
Posted on May 12, 2009
Why does it run continually?
possibly needs a service man to recharge the freon
Feb 18, 2016 | Freezers
I have whirpool chest freezer defrosted and off for 4 months then turned on 2 red lights going motor is running but not freezing turned up temp to coldest tempurature with amber light on stil the motor...
Since the motor is running, the compressor it is connected to must also be running. The compressor is the thing that provides the cooling under normal circumstances. The only thing I can think of as to why you are not getting cooling is that the refrigerant charge has leaked out of the system. I don't know anything about the red lights you mention.
Aug 25, 2014 | Whirlpool 10 cu. ft. / 283 liter Chest...
FREEZER THERMOSTAT
Sounds like the thermostat is not working. Mechanical and electronic thermostats can go bad and cause the freezer to continue running no matter what setting is set on thermostat. When this happens the only setting that will work is turning the temperature setting to off. What is the model number on your freezer? Sea Breeze
Apr 03, 2013 | Frigidaire Freezers
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
Freezer has quit freezing only a little over a year old. manufactor date 6/2009 compressor is running will only cool down to 50 degrees thermostat set on coldest.
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
Mar 06, 2011 | Kenmore 15 cu. ft. Chest Freezer 16542
The temp only goes down to 30 farenheit. the thermostat control knob is set to the coldest position. is the thermostat faulty or can it be adjusted?
Check list:
Fans running
Compressor cool to the touch
Not short cycling (low freon)
coils cleaned
no air restrictions
If all of that is good bypass the control
see if it gets down to 0
If it does replace the control
May 25, 2010 | Arctic Air 22 cu. ft. Commercial Freezer...
Freezer is running but food is thawing
If this is a self defrosting freezer, check amd make sure the evaporator fan motor is running and make sure there is no frost buit up on the back panel. Please let me know if either of these are the case so I can assist you further.
Thanks
Vic
May 23, 2009 | Freezers
Food in freezer not frozen; food in refrigerator not cold
1.check the coils on the back or under side.
2.check if compressor is running
3.check if copressor is hot
4.let me know the answers
Jan 14, 2009 | Freezers
Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
Apr 26, 2008 | Beverage-Air 20.7 cu. ft. / 586 liter...
LEC Fridge Freezer
clean up your condenser it's gotta be dirty and check your thermostat put it on the coldest setting and check your freezer fan.
if t ain't running check to see if wired with defrost thermostat if it is suspect it defective.
Dec 17, 2007 | Freezers
Freezers Logo
222 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
