Question about Electrolux Refrigerators
I have a frigidaire side by side fridge, FRS23R4AW9. It recently started freezing the fridge side, mostly at the top but everything will eventually freeze. Also froze the water dispenser line. How can I tell if it is the air damper or the thermostat? Is there a way to test each one?
  • Kristie steiger Mar 17, 2009
    Any insight?
    Can someone tell me where the thermostat is located?
    I unplugged the solenoid that opens and closes the door in the damper and rigged it about 3/4 of the way shut to see if that would help ( after I left the fridge door open for about an hour or so to help relieve some of the freezing)
    This morning a bottle of water is almost frozen so I am now thinking it is the thermostat.
    Is it located behind the fridge temp control dial?
    If so, how do I test it?
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Posted on Nov 25, 2008
  • 531 Answers
SOURCE: lights on water dispenser stuck on & fridge is starting freeze
you have to give me model# so i can help you
Posted on Apr 07, 2009
  • 378 Answers
SOURCE: My fridge is freezing things on the top shelf
meaning you have a uncontrolled compressor it run continuously without monitoring the temperature, The Temperature control or Thermo control switch. will switch ON the Comp. untill the preset temp. is obtain then Sw. OFF if the temp is out of preset value.
Posted on Jun 07, 2009
  • 4070 Answers
SOURCE: Frigidaire FRS23H5SB6 side-by-side freezing food
It sounds like the fan in the freezer behind the rear panel is not working. You should be able to hear it. It won't run with the door open so hold the door switch in.
Posted on Aug 09, 2009
  • 396 Answers
SOURCE: Samsung RS21DCNS Water dispenser freezing up
Sounds like you have the freezer temperature set too low.
Posted on Oct 10, 2009
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
Why is most everything freezing in my fridge. I have a fridgidaire elite.
Have you tried adjusting the thermostat level down several numbers to see if that solves the problem? It should be on the very top of the fridge portion when you open the door. Sometimes they are located in the freezer but most times the adjustment for fridge is in the fridge and freezer adjustment is in the freezer portion. If that does not work then you could be getting low on freon and it could be super cooling just before it runs out of freon. Try the adjustment first.
May 06, 2012 | Frigidaire Refrigerators
Refrigerator freezes everything even on low setting
Is it a single or double door? Assuming it is a double door. Normally the upper grade models have an auger motor that opens and closes electronically depending on temperature demand. This auger situated at the top LSD of the fridge normally freezes up due to various reasons. Most common is, product is placed to close to outlet which in turn creates a blow back effect and seizes the mechanism. Need to defrost fridge section for about 2 hours for ice to melt. Retry.
If it is a single door, your thermostat needs replacement. I'm taking it you have adjusted the settings higher(not so cold) but still not correct.
Sep 27, 2009 | Frigidaire FRS26R4A Side by Side...
My Frigidaire refrigerator side by side is freezing drinks.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS26H5AS Side by Side...
Fridge is freezing everything!
There is a flap that directs the air from freezer to fridge. Sometimes this flap can stick Or the actuator that controls the flap can go out. Same with autodefrost timer which seems to give a lot of people trouble. Thermostat is at the top, uncirculated cold air sinks, food in the bottom of the fridge freezes.
Sep 09, 2009 | Frigidaire FRS3R5EMB Side by Side...
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Jul 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
FRE196AS frigidaire fridge/freezer - fridge freezes everything!
Hello Nicola,
I suggest you contact Frigidaire in the UK, and explain the problem to them. I have included their website for you to do so. You can even call them. I checked with Frigidaire in the US and Customer Service tells me your fridge should not be failing at this point. Contact Customer Service and tell them how disappointed you are in the product; explain the issue; and insist they offer assistance to repair it. Frigidaire Customer Service here does not want to lose any customers, and that includes you. Be nice, but firm with them. I hope this helps you in some way. Let me know if I can further assist. Just trying to to help. :)
Feb 17, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
164 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
