Question about GE Ovens
JKP36G0H1BG time and clock stopped working
Main oven doesn't come on
Check to see if one of the knobs on the timer has a "man" setting. This is for manual. Many times the clock will shut off the oven and moving the clock dial to man will close the switch in the clock to allow the oven to work. If it doesn't have this "man" setting check to see if there is a start and stop time. Make sure the start is out and the stop is pushed in.
Mar 23, 2014 | Ovens
Twin ovens stopped working
Hi, Have you altered the time clock on the cooker? It is possible that the clock/timer is set for 'Auto'
Dec 26, 2013 | Caple Ovens
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
The oven won't work, neither elements, both stopped working at once. Stove top elements still work normal, as well as all other functions, just no oven. Tried to find fuses and could not locate any. Can...
It sounds like an electronic clock/timer problem. The clock must be in the manual mode for the oven to work. It sounds like it might be in auto. mode for both elements to stop working at the same time.
Mar 11, 2011 | Frigidaire Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
I have a 16 year old GE XL44 which has a manual turn clock that keeps buzzing. My husband stopped it, but it is going off again. The manuals I am finding on-line have electric clocks which we don't have....
Greetings,
Remove the power from the stove to prevent shock..remove rear access panal and locate clock....there will be a small motor attached to the clock..cut the wire going to the clock motor and tape....there are other ways, but this is easiest to explain..the clock will not be working after this...or, you can have your clock rebuilt or replaced with a current digital clock
Bruce Denton
Jan 04, 2011 | GE Ovens
We had a power cut yesterday and today my neff electric oven just shut down completely. The clock has also stopped working.
if you have power to oven but the clock is not working it sounds like overvoltage has damaged the clock if clock will reset and you can set the time oven will work.
Jun 03, 2010 | Neff B1421 Electric Single Oven
The timer clock has gone off.
to stop the clock area from flashing and for it to display time, the time must be set.
Apr 09, 2009 | Ovens
Function button keeps failing
only do this if you relay know what you are doing. try asking your local appliance second hand shop it will save you time and money
Nov 12, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Ovens Logo
53 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
