Question about Electrical Supplies
Coleman power ate 9375 won't start - Electrical Supplies
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: My Coleman Powermate 7000 won't
I not you said you "checked the oil level" My experience with most portable generators is that they must me positioned as level as possible and the oil level must be fully serviced as full as you can get it without oil leaking back out of the dip-stick hole on units WITHOUT an extended dip-stick. Unless those conditions are met the low oil level sensor ends up presenting a false low oil signal and it grounds out the ignition. DO you have Spark at all? If you do have spark and it still does not run respond with the MODEL number off of your ENGINE and I will show you where the main fuel jets are located so you can make sure the orifice is clean.
Some units have a fuel solenoid that presses into the main fuel jet recessed area and shut off the fuel to the carb. This is also an area that debris causes havoc.
Thanks,
Kelly
Posted on Aug 29, 2011
cts237
  • 29 Answers
SOURCE: Coleman Powermate 5000 won't start. Ran it
Check to see if you model has a puel pump, f it is a Brigge & Stratton 10 hp I am sure it does
Posted on Dec 12, 2011
Will a blown head gasket on my Coleman power ate 5000 era stop it from running?
It may run in this condition for a bit, but it will eventually stop running and be in need of serious repairs. I would find a shop to replace the head gasket or a manual and gasket and fix it before running it again.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/thomas_e8f475a8655f7b4a
Mar 16, 2016 | Coleman Powermate Powermate 5000W...
My acer aspire one notebook won't boot up.
Is the new cord/charger/transformer the EXACT same power specs? When your "dog ate your charger", it may have shorted out something in the Laptop? Was it plugged it when your dog ate it?
Jan 16, 2013 | Acer Aspire One PC Notebook
Coleman power ate 5000 generator, will start very easy, run for 1-2 minutes then shut down, what could be the problem?
Check oil level, and viscosity is correct 30W etc
Then check oil presure switch and wiring
Aug 28, 2012 | Coleman Electrical Supplies
I BOUGHT A USED COLEMAN 10 HP GENERATOR.IT STARTED FINE THE DAY I GOT IT,OW IT WON'T START AT ALL. ICHECK THE OIL.IT'S NOT LOW.I CHECK THE OIL FILTER IT'S NOT DIRTY. WHAT'S THE DEAL?
If it hasn't been used often it probably has a sticky Needle, this is situated on top of the float in the little tank Attached to the base of the carby, take the bowl off by a bolt at the base of it, remove the float, you will them see a small pin with a point on it, that is the needle, take it out and clean it and replace
Aug 20, 2011 | Coleman Electrical Supplies
Electrical Supplies Logo
49 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
