Question about LG Audio Players & Recorders
LG XC120 Micro hi-fi system -when volume low, i hear the CD unit
I just bought the LG XC120 Micro hi-fi system and when i leisten to CDs on low volume (maybe up to 7) i can hear the sound of the CD unit or CD turning inside the unit. Is this normal? when i increase the volume, it covers the sound of the CD turning inside.
rizla
  • 1463 Answers
SOURCE: Setting the clock on a Philips MCB240
hi
will this help
a user guide download and search the clock settings hopefully this will solve it .
PHILIPS MCB240 Micro Hi-Fi
riz.
Posted on Feb 26, 2008
SOURCE: how do i reset a
push the funtion button till dab bomes up on the screen then push in the info button and it will start to retune dab. for a total reset just push the select button 1 second after you hold the info button for 5 seconds
Posted on Mar 10, 2008
SOURCE: noisy at very low volume!
I had the same problem... if it's mechanical... this is the solution....under the lid is a free floating magnet clap which centers and sits on top of the dics when the lid is closed.This rides to low when the lid is down and rubs on the inside lip of the lid which prevents the clap from falling out... solution... cut a piece of scotch tape the same size (circle) as the inside magnet surface of the clap... stick it on...now the clap with magnetic clap as before but will be a few 1000ths higher...mike
Posted on Mar 28, 2008
SOURCE: CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
Posted on Apr 09, 2008
SOURCE: Low sound volume when watching DVD's
(bad english warn)
so... i just found out that i had turned almost to 0 the volume on Nero ShowTime... and it just gets the windows volume down not just for that program bt everything... even winamp got itself on maximum volume and i couldnt hear almost nothing in all my sound system with the volume at max.
so heres the solution...
OPEN YOUR DVD PLAYER (nero ST or whatever it is) AND TURN VOLUME TO MAX. AND ONLY DECREASE IT ON WINDOS (SPEAKER ICON)
Problem Solved
fell good to help!!!
best regards from Brasil
Posted on Apr 12, 2008
I have a Samsung SCM-7450 Hi-Fi System. The CD player has stopped recognizing that there are CDs ready to play. Any suggestions?
There is nothing you can do and I doubt leaving the CDs in the unit would have made any difference with the problem you have now.
The CD player is an integrated unit with tape player, turntable etc so there are presumably no connections on the back of the unit that would allow you to connect a new CD player and run it through the unit. However, if it does have compatible connections then that is what I would do.
Dec 26, 2015 | Audio Players & Recorders
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Low drone on TEAC X2501 micro Hi Fi system
Could be due to the frequency of the Brasil voltage. The UK one is 50Hz, is the Brasil one higher? If it is you will need to put higher value capictors in, or get a mains adapter.
Jul 11, 2009 | Electronics - Others
Sony Mini Hi-Fi MHC-MG110 no longer chooses CDs at random
Unplug the power for a while and load all CDs. It could solve the playing old paylist.
Jan 10, 2009 | Sony MHC-MG110 CD Shelf System
Volume Control??
Unlike low-end hi-fi systems where you buy one box that does everything, the CD player you have is part of a component hi-fi system (i.e. you buy your CD player, tuner, amplifer etc. as separate items.) This is why there is no volume control. It needs to be connected to an amplifer. It's on the amp that you will find the volume control and where you connect the speakers. (When you connect it to your television, you are just using that amp in the TV instead.)
The CD player did originally ship with a remote control, but I don't know where you would be able to buy one on its own. You may find the the remote does allow you to alter the output level of the CD player, but you still need to connect it to a proper amp to get it to work.
Hope this helps,
Matt
Mar 27, 2008 | Technics SL-PD887 5-Disc CD Changer
hi
will this help
riz.
Feb 26, 2008 | Audio Players & Recorders
Technics cd hi-fi
hi bobro, when burning the cds, make sure that you are burning it as an audio cd, as this player does not support mp3 formats, just normal audio cds... hope this helps!
Feb 11, 2007 | Technics SCEH790 CD Shelf System
LG F-185 AD (AKA LG FFH-185-AD) - No sound when CDs are played
Hun guys.
Could you please help me to spurt out this issue that I was looking for price of this as I wanted to buy this.
Sep 28, 2006 | LG F-185 CD Shelf System
48 people viewed this question
Top LG Audio Players & Recorders Experts
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
