Microsoft Virtual PC 2007 on Toshiba Laptop
Hi
I installed Microsoft Virtual PC 2007 on Toshiba Laptop P200 but when i try BackTrack 4, i cannot get the GUI interface to start using the startx command, i got addscreen fatal error
  • 31 Answers
Your system files will be at location C:\Program Files\Microsoft Virtual PC on your laptop & look/search for My Virtual Machines folder on your m/c for the location of the virtual HDD you have installed. Drag n drop the drive from this location to the Virtual PC Console mentioned earlier above...
Posted on Mar 13, 2009
BackTrack 5 R2 64-bit bank startx on Acer Aspire 5742problem?
Use the LIVE CD option to test before installing.
Oct 16, 2012 | Computers & Internet
I want to know the command you need to enter on Linux Red Hat to get to the GUI
Manual Method:You can start the X terminal GUI application each time you need it by running the "startx" command at the VGA console. Remember that when you log out you will get the regular text based console again.
[root@bigboy tmp]# startx
· Automatic Method: You can have Linux automatically start the X terminal GUI console for every login attempt until your next reboot by using the init command. You will need to edit your "initdefault" variable in your /etc/inittab file as mentioned in the preceding section to keep this functionality even after you reboot.
[root@bigboy tmp]# init 5
Nov 01, 2010 | Computers & Internet
Fedora not working gui mode
The  x-server doesn't start. Try to start it thru command mode using the startx command. The cause for this is usually a bad xorg.conf file - the file that holds the configuration of the x-server. Just delete it thru command and a new one will be generated.
Jun 04, 2010 | AcerPower Sn PC Desktop
Virtual PC 2007 does not open in Vista Ultimate 64-bit OS
right click>> setting(or propertis) run with this mode>> XP set.
Feb 15, 2010 | Microsoft Virtual PC for PC
I absolutely hate vista....i wasn't able to transfer my microsoft money so had to download quicken and transfer info...then twice now i have had to reinstall quicken because it won't open up...i guess it...
There is a work around to getting Windows XP programs to work under Windows Vista - Virtual PC 2007.
Virtual PC 2007 is a free download from Microsoft and it allows you to install any operating system and run it in a "window" on your Vista desktop.
Download Virtual PC 2007, create a Windows XP virtual machine, install Microsoft Money and transfer in your data. You can install Quicken as well.
The virtual machine will use your PC's actual connections (network, serial and printer but not USB) to connect to devices and the Internet.
Again - this is a work around that is proven to work. One side benefit - you can copy the virtual machine to an external hard drive / USB memory stick and run it on any comptuer that has Virtual PC 2007 installed on it.
Hope this helps
Nov 18, 2009 | Microsoft Windows Vista Ultimate Edition
Can I use this software on a new MAC laptop?
You have to purchase the MAC version of the software. You can install Virtual PC on the MAC, then you can install any windows software and run it on your MAC in the Virtual PC mode. Beware that Virtual PC uses a lot fo resources while running.
Apr 07, 2009 | Microsoft Office Professional 2007 Full...
Installation of MS SharePoint 2007 in Dell Inspiron 1525 Laptop
SInce SharePoint Services 3.0 and SharePoint Server 2007 does require a server interface to run the collaboration tools you are unfortunately stuck with running it on server software. But all is not doom and gloom as there is an option for you to run Microsoft's Virtual PC. Here is an article on how it works from Microsoft. (http://windowshelp.microsoft.com/Windows/en-US/Help/97a74f0e-798d-45ff-b9bf-7feed68c40e51033.mspx) . This allows you to not ony run your native Operating system, but also run SharePoint on th esame machine in a virtual environment.
Jan 09, 2009 | Dell Inspiron 1525 Laptop
Sync'ing outlook 2007 with Toshiba PocketPC 2002 e335
nope ....the outlook 2007 doesnt support all the connecting devices
Feb 28, 2008 | Toshiba e335 Pocket PC
Open Questions:
Online backup and storage 'DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
May 25, 2018 | Quantum Computers & Internet
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
